| Author |
Message |
ShortVehicle
Joined: Fri Jun 08, 2012 11:43 pm Posts: 33 Location: Bullsbrook (WA)
Vehicle: Suzuki Stockman LJ80 Soft Top
 Posted: Thu Jun 14, 2012 11:22 pm |
Looking for a tow bar for an LJ80
Anything considered
I am in WA
Paul J
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5935 Location: Northcliffe, W.A.
 Posted: Thu Jun 14, 2012 11:36 pm |
ShortVehicle wrote: Looking for a tow bar for an LJ80
Anything considered
I am in WA
Paul J I've got one on my LJ81 you could have. I'd have to check (will tomorrow, it's dark and wet outside) but I think it may be welded as well as bolted on, I have another but that is completely welded on and getting it off would most likely destroy it. I'm pretty sure it'l fit your LJ80, measure the distance between your chassis rails at the rear.  This is probably the best pic I have.  Where abouts are you?
ShortVehicle
 Posted: Fri Jun 15, 2012 12:05 am |
sideways,
I am up in Bullsbrook - north of Perth
I will have a measure tomorrow and post
My LJ80 is an open top two seater Ute
sideways
 Posted: Fri Jun 15, 2012 12:22 am |
ShortVehicle wrote: sideways,
Cheers Cool, I'm about 400kms south of Perth... Haha. If you're in no hurry, I can bring it next time I head up to Perth(no idea when that will be, possibly soon) and we can sort something out.
ShortVehicle
 Posted: Fri Jun 15, 2012 12:35 am |
Sounds fine - no rush - I will measure and let you know
The tray back looks like a bit of fun...
sideways
 Posted: Fri Jun 15, 2012 12:56 am |
ShortVehicle wrote: Sounds fine - no rush - I will measure and let you know
The tray back looks like a bit of fun... Cheers. Yeah, the tray back is awesome, though it's in 767856 pieces right now.... really need to find a better cab. Put up some pictures of yours.
sideways
 Posted: Fri Jun 15, 2012 6:03 pm |
I had a look at the tow bar, looks home made (read, a bit dodgy). You'd need to cut or bend the back tow hook things to fit it too. It looks like someone has chopped up a towbar from another car to make this one fit. It'd be fine for anything you can legally tow with an LJ80 I think. 785mm between the 2 mounting surfaces (mounts the the inside of the chassis rails). Yours if you want it.
ShortVehicle
 Posted: Sat Jun 16, 2012 12:56 am |
Got back pretty late from work and not had time to check
Will measure up tomorrow
Only looking to tow trailer that I usually tow with Quad bike......
Will have to upload an Avatar and some pics = newbie here so not entirely sure how to do this yet
ShortVehicle
 Posted: Mon Jun 18, 2012 11:22 pm |
Thats odd measured mine earlier and its 865mm ??
May not fit with out a major mod
sideways
 Posted: Tue Jun 19, 2012 12:00 am |
ShortVehicle wrote: 785mm between the 2 mounting surfaces (mounts the the inside of the chassis rails).
May not fit with out a major mod Between the inside of each chassis rail? I'm soon to acquire 2 SWB LJs with tow bars. I'l let you know what theirs are like.
ShortVehicle
 Posted: Tue Jun 19, 2012 12:13 am |
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Tue Jun 19, 2012 6:49 pm |
Guys you are on the wrong track, they are completely different at the back of the chassis it will not fit, The tow bar on a soft top LJ is very basic and bolts to the plate in the centre of the rear cross tube.
Boggomobile
Joined: Tue Oct 04, 2011 8:43 pm Posts: 640 Location: Northern NSW
 Posted: Tue Jun 19, 2012 10:11 pm |
Hi All,
If you are still looking for a LJ80 tow bar, I can help you, just PM me an email and I will send you some photos.
_________________ COOL BANANAS!
ShortVehicle
 Posted: Tue Jun 19, 2012 10:21 pm |
Thanks 2stroker - thought the dimensions were odd
Boggomobile sent you a PM
dingoworx76
Joined: Mon Dec 19, 2011 10:11 am Posts: 13 Location: Northern SA
 Posted: Thu Jun 21, 2012 9:25 pm |
I have one, will sell it for $100. located in Pt Augusta SA
_________________ SIT DOWN, SHUT UP, HOLD ON!!!!!!!!!!!!
ShortVehicle
 Posted: Thu Jun 21, 2012 10:35 pm |
But it does not look like it will fit on mine
ShortVehicle
 Posted: Thu Jun 21, 2012 10:57 pm |
Boggomobile sent you a PM but heard no more?
Boggomobile
 Posted: Fri Jun 22, 2012 6:57 pm |
ShortVehicle wrote: Boggomobile sent you a PM but heard no more?
Cheers Hi All, Had to do a little digging, found one and sent a photo by email!
ShortVehicle
 Posted: Wed Jul 04, 2012 10:36 pm |
Cheers Mate,
Recieved it in the post today - fitted this evening all good
Thanks
Paul J
