It is currently Sat Jul 18, 2026 3:32 am
Vehicle: 91 sierra s/t, g16b, 31's, etc
Post Posted: Sun Jun 03, 2012 9:45 pm
Chasing bits to get my baby back out there.
Had sludge release in the rocker rail, block three journals and five rockers.
It's just eaten itself!!
In need of replacement port injection head and vitara cam.
Appreciate help from anyone with those bits/motor.
Post Posted: Mon Jun 04, 2012 7:36 am
Where are you locate mate
Post Posted: Mon Jun 04, 2012 1:00 pm
^^x2 If you are in briz I may know of a G16 head and cam
Lil Foot!
Post Posted: Mon Jun 04, 2012 4:23 pm
I am the person JrZook knows that has a spare G16 head (untested), Also have a G16A motor sitting here which works. So if your in bris let me know.
Post Posted: Tue Jun 05, 2012 2:00 pm
G16BA?????
It is either a G16A or G16B
Can't be both.
Is it 8 valve carby or 16 valve EFI?
Post Posted: Tue Jun 05, 2012 3:10 pm
He says its a port injection head so still could be either an A or a B but obviously 16 valve
Post Posted: Tue Jun 19, 2012 11:07 am
Sorry guys, got sent to Groote Eylande for two weeks.
Donk is G16BA, 94 Vitara multi port injection.
I'm not worried were you guys are, I'll freight it no problem.
I'll try making my profile photo of it
Post Posted: Tue Jun 19, 2012 11:14 am
DAMMIT wrote:
Sor
No such thing as a G16BA mate.
Only G16A or G16B.
Either way, you need a 16v head.
Post Posted: Tue Jun 19, 2012 5:47 pm
Block is stamped G16BA, have another 16v head but it's not port injection, mate.
Post Posted: Tue Jun 19, 2012 6:40 pm
I have seen acouple of those blocks and have one of those blocks at the moment, it has G16A on the bellhousing face and G16B on the engine number.
Sorry mate head is gone.
Post Posted: Wed Jun 20, 2012 9:55 pm
Was just chatting with a bloke who has seen this motor before, he went on to explain about the three different aussie importers & how WA seemed to get an American type of version. As in, when the rest of Oz got a carby suzuki, WA got the same car in efi.
Now I don't know if that's what's going on here, but the donor car was WA rego'd, and when I was extracting the ecu and wiring it had an emission control system the wiring diagram states as only on californian vehicles. So, the question is, do the mid 90's 16v efi heads have the same relief at the top of the port for the injectors, as previous post say I only need a 16v head & I have another 16v G16B motor & the blocks look identical but the head does not have the injector reliefs.
Post Posted: Thu Jun 21, 2012 6:06 am
Ports in question.
Vehicle: LWB Sierra & XL7
Post Posted: Thu Jun 21, 2012 8:37 am
That kinda looks like mine. Which is a G16b.
I've gotta pull out the engine in my Vit so I'll have the head available shortly and I have a cam ready to go now. Where are you located?
this is one I just had rebuilt, so it's not for sale.
'92 Vitara & Camper trailer
Post Posted: Thu Jun 21, 2012 11:05 am
Hell yes! That's the bastard there! The casting imprints at the top are a bit different, mine doesn't have numbers or characters either, but close enough! I'm up in Darwin, so you get used to paying the postage on everything. Let me know what you want for them, but I'm back out bush again on Tuesday for two weeks, cheers, Rob.
Post Posted: Thu Jun 21, 2012 11:13 am
Well, at this stage it won't be until 1-2 weeks until I get this motor ripped out.
The head pictured is from a 94-98 G16b Vitara, Mine is an early model, but I'm sure they'd be the same. Unless someone else here knows off the top of their noggin, I'll confirm it once I remove it.
I do have the '94-98 cam which is ready to be sent. I'll be using the cam that's in my current engine in the head pictured.
Post Posted: Thu Jun 21, 2012 12:36 pm
That head is just a 16V MPFI head which is pretty common. Only some early 1600 swifts and imports have no injector reliefs because they were running a throttle body injection unit.
Lil Foot!
Post Posted: Thu Jun 21, 2012 4:23 pm
Yep that would be it, the ones I can find here are throttle body with no reliefs, still marked as g16b. Old mates photo, other than numbers & patterns, looks identicle at the ports. Thanks guys, finally confirmed as a g16b MPFI
Post Posted: Thu Jun 21, 2012 5:19 pm
there are stacks of throttle body injected vitaras in the nt. i had 2 for work cars, both were 94 4 door jobbies.
Post Posted: Tue Jul 03, 2012 7:05 pm
PM sent
