It is currently Thu Jul 23, 2026 11:35 am
Post Posted: Mon Apr 20, 2009 12:01 am
So finally broadcasting my problems of late :P
I had been having problems with timing and carby in the last month, got the carby sorted (i hope) but the distributor seemed to be the prob with the timing.
It all came to a holt the other weekend when it refused to start after making a weird sound, whilst down at the servo. (luckily zukchik's ute came to the rescue haha)
After pulling it to pieces the rotor button wasn't turning while cranking. The distributor cog had a big chunk out of one of the teeth. The shaft movement of the distributor was about 8-10mm so i figured that it must of jumped a cog taken a chunk out of the tooth and then sat in that position and not been connecting with the cog on the camshaft causing it not to start.
Easy... get another distributor... got a good s/h one, checked over the cog on the camshaft...looked fine no marks or anything...beauty.
Put the new distributor in, roughly set timing, start it up..makes a weird grinding noise, turn off, pull distributor out and a tooth has a chunk out of it on the new distributor.
Check camshaft cog again, is perfectly fine :x
So I am unsure of where the problem lies here, doesnt seem to be obvious camshaft movement, new distributor doesnt have movement, housing looks alright.
Really hoping it isn't a bent camshaft, any ideas/thoughts/suggestions?
Post Posted: Mon Apr 20, 2009 12:17 am
spin it over with the dizzy housing off to see if the cam is spinning true? I reckon if its enough to snap teeth you would see it
Post Posted: Mon Apr 20, 2009 12:45 am
Have spun it over slowly a few times and it seems to be spinning true, only had the calibrated screwdriver to test it lol but no huge movement.
Post Posted: Mon Apr 20, 2009 2:46 am
Petrol + Match = Problem Solved
Post Posted: Wed Apr 22, 2009 11:54 pm
Ok so i got a bigger screw driver and a hammer and the camshaft slides back and forth.
Had bit of a look through the manual and can't seem to work out how the camshaft is held in
Post Posted: Wed Apr 22, 2009 11:55 pm
it's held in with glue & some pop sticks...... sorry I know nothing :wink:
Post Posted: Thu Apr 23, 2009 5:18 am
Camshaft is held in by the rocker assembly. Pull the rocker cover off and check the rocker assembly. If it's sliding back and forth I'm guessing your rocker assembly and camshaft bearings are going to be stuffed, so you'll be up for a new rocker assembly, camshaft and camshaft bearings.
Post Posted: Tue Jun 09, 2009 2:02 pm
Problem still not solved.
A local head builder said the dist housing holds the cam in place, so i'm at the point of trying a new housing to see if that somehow is the problem.
I'll get pics of the dist cog tonight just for Damo haha
Post Posted: Tue Jun 09, 2009 2:31 pm
Pain, just take one of jo's many !
Yep see sig below!!!! hehe
Post Posted: Thu Jun 11, 2009 1:46 am
pics
Post Posted: Thu Jun 18, 2009 3:09 am
Ok well seems it was the distributor housing that was the problem, when the orginal dist was stuff it must of stuffed the housing aswell!
Now just to get it to start after 2 months haha
Post Posted: Thu Jun 18, 2009 3:24 am
Ready by this Saturday? We going to Beachport & there's a race on at buggy park. Wanna come with?
Post Posted: Thu Jun 18, 2009 5:37 pm
Hopefully ready but wont be wheelin, got footy and heading to adel for next week so if this pos is going we'll have to go for a wheel in the pines the following weekend!
Post Posted: Thu Jun 18, 2009 9:53 pm
footy boofhead :P
Post Posted: Fri Jun 19, 2009 9:50 pm
Surfer bum!
Still wont bloody start tho!
Post Posted: Fri Jun 19, 2009 10:34 pm
LOL
Hmmm.. bugga
Maybe theres another problem .... on going chain of events haha
Post Posted: Sat Jun 27, 2009 11:57 pm
ok it starts and runs and is driving :D just was a timing adjustment issue on the no start!
Post Posted: Sat Jun 27, 2009 11:59 pm
Post Posted: Sun Jun 28, 2009 1:45 am
It LIVES!!!!
Users browsing this forum: Google [Bot] and 63 guests
