i use to run commodore shocks in front but with 2 inch shackles the shocks use to restrict down travel as there not long enough,so i limited the up travell to allow for more down travel and used a longer shock,with limited up travel was good as would stop tyres rubbing or getting cut up on the front gaurds
i ran 30"long ranchos on the back layed over using a piece of 50x50box between the standard rear mounts and the body and bolted them up to that
Users browsing this forum: Google Adsense [Bot] and 184 guests
