It is currently Fri Jul 17, 2026 5:44 pm
Post Posted: Fri Oct 12, 2012 7:16 pm
Started putting my 3" calmini lift in my vitara an now could really not be bothered.
Anyone interested in finishing it for me.
I just pulled the calipers off haha that's all I've gotten too
Post Posted: Fri Oct 12, 2012 7:17 pm
why did you need to remove the calipers? :?
Post Posted: Fri Oct 12, 2012 8:10 pm
Pretty much step 3 or so in instructions
Post Posted: Fri Oct 12, 2012 8:13 pm
instructions, who reads instructions.... what sort of man are you? :lol:
Post Posted: Fri Oct 12, 2012 8:29 pm
That's what I'm doing wrong haha
I was wondering why I needed to do that. Instructions aren't in that much detail.
I almost dropped the cvs completely out. Lucky for the Internet.
So you flying up Gus? I am so not motivated to install it.
How long does it usually take?
Post Posted: Fri Oct 12, 2012 8:32 pm
i did the blagon in about 8hrs by myself stopping for heaps of smoko breaks.
i start in the rear & do that first as it's the easy bit.
Vehicle: Suzuki Grand Vitara
Post Posted: Fri Oct 12, 2012 9:09 pm
Same here didn't have to remove calipers or cvs.
Post Posted: Fri Oct 12, 2012 10:40 pm
Yeah, rear gets you into the swing of it and it's a doddle. Then again, you could go the other way and save the easy bit til last, get the headache out of the way first...
Just do it swifty, hit one side at a time, get up and get the first side done before lunch, second side before dinner, and rear will take you two hours tops in the evening.
Jack up, chassis on stands
Remove wheel
Unclip brakeline from strut and chassis mount (top of spring mount)
Undo swaybar and tie rod from control arm
Jack under control arm, just to support weight (leave 3 balljoint bolts accessible if possible)
Undo bottom strut bolts
Support hub (tie knuckle up to chassis or something, just to stop the weight falling on the brake line or the CV pulling out)
Undo top strut nut
Remove strut
Undo balljoint bolts
Loosen control arm chassis bolts
Lower control arm using jack
Remove spring
Undo control arm chassis bolts
Remove control arm
Rinse and repeat.
Do the diff drop while you've got everything else out of the way - two jacks will make life easier.
Reverse steps with the new blue bits subbed in.
(I realise it's a fair bit easier when you've done it half a dozen or so times...) ;) You've done heaps harder jobs on that thing!
Post Posted: Sat Oct 13, 2012 6:11 am
Don't forget to grind down the diff lip. (In the instructions)
Post Posted: Sun Oct 14, 2012 8:58 am
This is shit. I haven't even done 1 side. Some one come help.
Lots of beer/money involved
Post Posted: Sun Oct 14, 2012 10:22 am
fly me up or bring it down here & i'll do it.
it's not that hard, i work on computers & even i managed it. you've thrown you hands up & called it to hard too early :?
Post Posted: Sun Oct 14, 2012 11:08 am
I'll be up in Bris with some time to kill in early December if you can wait that long...
Post Posted: Sun Oct 14, 2012 1:49 pm
It's not hard but it's too just annoying. The instructions are very vague. My copy didnt mention grinding down the diff.
I've just got some spring compressors so hopefully have the front done this week lol
Thanks Darkhorse and Atari. I'm just too old to work on cars
Post Posted: Sun Oct 14, 2012 2:09 pm
:lol: Get at it Gramps!
I've never heard of grinding the diff... certainly never done it myself...
Spring compressors are evil, and fucking dangerous if something goes wrong. Be careful.
I bought my kit very second hand, with no instructions, so don't know what the supplied ones are like. I did quite a detailed write-up and pic fest when I did mine, so hopefully that helps a bit...?
viewtopic.php?f=4&t=11477&start=390
Post Posted: Sun Oct 14, 2012 2:11 pm
old :rofl: you're just a pup from memory? P plate in your avatar :deadhorse:
try doing it with a fucked knee/thigh bone full of titanium screws/plates & every time you get up or bend it makes wicked grinding noises & fells like you're rubbing 2 rocks together. :twisted:
steel diff won't need grinding, shouldn't need spring compressors if the front end is high enough off the ground. get the control arms in & let them hang, offer the spring up to the top spring seat & swing the control arm up & get the tail of the spring located in the lower spring seat about 5-10mm from the end of the spring seat. i then use a bottle jack in the round drain hole on the bottom of the control arm & carefully jack the control arm up so the spring seats & holds it in position so you can get the knuckle re attached & the strut bolted back up.
BE FUCKING CAREFUL when jacking the control arm & make sure it's not going to slide off the jack. also don't put you fingers/hands where you wouldn't put you dick.
bloody Gen Y'ers, you give up to easy. :thefinger:
Post Posted: Sun Oct 14, 2012 2:21 pm
You give up way too easy, i thought you sold this car?
Post Posted: Sun Oct 14, 2012 4:06 pm
I bought a TJ wrangler and this thing was sitting in my shed waiting for hilux diffs but then i realized jeeps break just as much.
I'll smash it out during the week.
I am soft in my old age
Post Posted: Sun Oct 14, 2012 4:09 pm
swifty_ano wrote:
I bought a TJ wrangler and this thing was sitting in my shed waiting for hilux diffs but then i realized jeeps are gayer than coilys.
fixed for truth.
out of interest, how old are you ant? :wink:
Post Posted: Sun Oct 14, 2012 4:18 pm
20 years old, Gus ;)
Post Posted: Sun Oct 14, 2012 4:28 pm
just a pup :thefinger:
Vehicle: Vit
Post Posted: Sun Oct 14, 2012 7:41 pm
Lol mate I feel yr pain took my bro and I 5hrs just to get my diff drop brackets in...seriously annoyin just couldn't get em to line up :P good luck :)
Post Posted: Sun Oct 14, 2012 7:44 pm
lucky you get paid by the hour & not by the job. :lol:
Post Posted: Sun Oct 14, 2012 8:46 pm
Quote from another install.
Theses two parts need modifying.
"Factory base that mounts to the cross member, new Calmini bushing w/ cut sleeve inside, new Calmini center link bracket that mounts to the differential, factory top bushing and cap. 12- Grind the rib off of the bottom of the differential housing (It will be contacting the cross member after you remove the bracket in step 9)(oops, forgot a picture)."
http://www2.izook.com/?page_id=159
http://www2.izook.com/?page_id=160
Post Posted: Mon Oct 15, 2012 6:20 pm
NFI - I'm using the later style of mount, so no Calmini bracket.
Post Posted: Mon Oct 15, 2012 6:23 pm
steel diff doesn't require grinding
Users browsing this forum: No registered users and 19 guests
