It is currently Mon Jun 08, 2026 2:23 pm
Vehicle: Suzuki sierra
Post Posted: Tue Oct 16, 2012 1:04 pm
Hi I was just wondering how can you repair a stripped spark plug hole without taking the head off.thanks Reece
Post Posted: Tue Oct 16, 2012 1:07 pm
Helicoil.
There's a bloke here in brissie that specializes in repairing damaged threads, try searching for someone like that in your area
Post Posted: Tue Oct 16, 2012 1:34 pm
Thanks mate
Vehicle: SJ80, SE416
Post Posted: Tue Oct 16, 2012 5:05 pm
How dodgy are you?
Years ago I nicely cross-threaded a plug on my old Corona engine. My stepfather fixed it for me by using a file to cut the thread on an old sparkplug so it turned into a tap and then threaded the 'tap' into the block! Worked a treat!
Nah don't do that - Scrawn's advice is better!
Post Posted: Tue Oct 16, 2012 5:12 pm
Get one of these kits mate
Put some grease on the tap and carefully start it in the plug hole. Make sure the piston is at the bottom of the cylinder and drive the tap in as far as it goes
In the kit there are a stack of different thread lengths, choose the one that matches the spark plug thread. Then screw the thread onto the plug and screw both into the new plug hole untill it bottoms out. Carefully remove the plug leaving behind the thread in the plug hole.
The smooth thread bit goes on the hole first
Then stick this bit in the hole taking care to have it square to the new thread thingo and then flog the piss out of it with the biggest hammer you can find.
It is a great spark plug fixing kit and only costs $50 so is also great value.
Post Posted: Tue Oct 16, 2012 5:50 pm
I'm all for people having a go at things but broken bolts or damaged threads usually end in tears more often than not. The guy we use for this stuff is reasonably priced, quick and does fantastic work. I will always recommend using him over a novice having a go, it just gets too costly too quickly
Post Posted: Tue Oct 16, 2012 5:59 pm
I agree with ya scrawn however the kit I posted is as foolproof as it gets and not everybody has the luxury of being able access a pro thread fixer.
Vehicle: LJ20 LJ50
Post Posted: Tue Oct 16, 2012 6:27 pm
Did Ball tell you to get fucked that day????
Camels have nice toes
Post Posted: Tue Oct 16, 2012 6:30 pm
Narh he didn't have any helicoils and that was what I came up with. it is a good kit.
Post Posted: Tue Oct 16, 2012 6:46 pm
Thanks heaps guys
Post Posted: Tue Oct 16, 2012 6:50 pm
I hear ya! pompoms
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue Oct 16, 2012 7:15 pm
Nice kit shepherd iv never seen that before
Users browsing this forum: No registered users and 6 guests
