I am 99% certain that a g13 dizzy will do the job
I am 99.99% sure they are the same provided they are both a right angle drive. The head (g13ba vs G16a) is the same casting except for port/valve sizing, the sierra dizzy housing will bolt to a vitara head also the camshaft is the same other than lift/duration but the drive to the dizzy is the same. You might just need to change a plug to suit the loom.
