| Author |
Message |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat Jun 20, 2009 2:17 pm |
I've put a 8V head onto a 16V 1.6 block and the timing belt is too short...
I know other people have done this before... What belt did they use?
Iremember 11-EVL saying something about a Honda belt but can't remember the part number.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sat Jun 20, 2009 2:28 pm |
How short is it? Aren't the tensioner bearings different?
want33s
 Posted: Sat Jun 20, 2009 3:15 pm |
ScrawnC wrote: How short is it? Aren't the tensioner bearings different?
Tensioner roller is same OD.
Belt is "about" 60 mm or 6 teeth too short..
I could go and buy a longer one and try it but these things aren't cheap so I'd rather learn from someone elses experience.
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Sat Jun 20, 2009 3:43 pm |
Any reason for the swap???? what benefits does it give??
want33s
 Posted: Sat Jun 20, 2009 3:45 pm |
twitchy wrote: Any reason for the swap???? what benefits does it give??
Yes.. My old 1.3 is VERY tired.
1.6 bottom end was only $50 plus parts to rebuild.
1.3 reco'd head was $100.
So its a cheap new motor.
Benefits... Helps my wallet not die of malnutrition.
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Sat Jun 20, 2009 4:26 pm |
the only difference between 8 valve and 16 is the thickness, not the length.
_________________ builder of custom road legal zooks......and stuff.
twitchy
Vehicle: 1999 Jimny
 Posted: Sat Jun 20, 2009 6:12 pm |
thought ya might of found a performance enhancement.....lol.
11_evl
Joined: Tue Apr 10, 2007 11:30 pm Posts: 846 Location: logan reserve, Brisb
 Posted: Sat Jun 20, 2009 6:41 pm |
t100 honda belt is the one i used. i cant remember what specs i used, width gear wise
_________________ 92 sierra, 40" treps, full hydro, F&R steer, 106"W
want33s
 Posted: Sat Jun 20, 2009 7:11 pm |
joeblow wrote: the only difference between 8 valve and 16 is the thickness, not the length. I know for a fact that my 1.3 8V belt is too short. I have already changed the crank pulley to suit the 1.3 8V cam pulley. 11_evl wrote: t100 honda belt is the one i used. i cant remember what specs i used, width gear wise
Thanks Michael.
joeblow
 Posted: Sat Jun 20, 2009 8:00 pm |
Ummm....yes.
you're 1.3 belt IS too short as the 1.6 block is taller.
the swaps i have done like that i have use vit pulleys....not sierra ones.
my above post was refering to vit belts only 16v to 8v, and not the sierra ones.
