It is currently Thu Jul 16, 2026 7:35 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2
Post Posted: Wed Jan 16, 2013 8:18 pm
Jake terry wrote:
I'm looking at all the posbiletys for doing this
Doing what?
You've been told numerous times what you need to run 31's, but you don't seem interested, and you keep banging on about shackles. So you want someone to tell you that you need long shackles to run 31's?
Post Posted: Wed Jan 16, 2013 9:00 pm
Do a leaf over its easy just flip your diffs over and bolt em on under the springs then screw a couple of four inch bits of wood in between your body and chassis , then you'll be right for 35s mate.
Is that what you wanted to hear??
Post Posted: Thu Jan 17, 2013 4:49 am
Jake terry wrote:
Ok I'm going to take some photos and post up in the morning plus i know wht I'm going to do I just need shackles for now for my beach run on the 20th my bro said I need 4"inch shackles and modded bump stop to stop it bottoming out on the well the I hav to grind off the sharp edges on the on the front side step area and take as much of the bull bar back where it bolts on as possible then when I get a new job do it all up properly because I hav a spear side under door plates to replace them
sorry jake but let me get this right, you want to fit 31's to your stock sierra so you can do a beach run? You may not be aware but a sierra with stock gearing and 31's is a horrible combination for sand and your clutch won't last long. Your sierra will be much more capable on the sand with the stock tyres you are running at the moment.
Stop being a numpty and listen to the people who are trying to give you some great advice. Stop and take your time to read through what everyone has told you..Here is where you can buy the requested shackles. If you don't want to spend this much then creat a less confussing wanted thread with you exact requirements (eg exact shackle length) or you could always make your own shackles if you can weld.
Rusho wrote:
Jake terry wrote:
Dos anyone have shackles or not that's all I want
http://www.auszookers.com/forum/viewtopic.php?f=15&t=13126
SIERRA EXTENDED SHACKLES $259.00 FREE POST
This bloke has heaps of them pompoms pompoms
If you would like an alternative to fitting long shackles and don't really want to spend a heap of money here is the information
SierraDan wrote:
Put a 25mm spacer on the front bumpstop.
Hammer your guards smooth.
Bolt the 31's on.
This method is possible, just get a big hammer and massage the inner parts of the guard that get in the way of the 31's.
Jake terry wrote:
Is there any major mods needed for a ruf
Aren't you doing a spring over?
You have been told how to fit 31's numerous times It's easy to do and it's been done hundreds of times before.
Truth
you're making life really hard for yourself.
Truth
hillbilly wrote:
I'm a stick farmer don't listen to me
Truth
Vehicle: Suzuki sierra
Post Posted: Thu Jan 17, 2013 5:40 am
I was just trying to get the info on all the other ways to do it and i have spoken to a engineer and it'll cost me about 800-900 to go that option so I'm going RUF
Post Posted: Thu Jan 17, 2013 5:50 am
Which option ? You've been given a few. You still need to engineer Ruf if that's what your worried about.
People are going to think you are really just the stick farmer in disguise.
Post Posted: Thu Jan 17, 2013 5:52 am
I want something that doesn't need a engineer cert
Post Posted: Thu Jan 17, 2013 5:53 am
And I was taking about spoa
Post Posted: Thu Jan 17, 2013 5:58 am
Then stick with standard tyres or 50 mm bigger tyres only and two inch suspension lift cause everything else needs to be engineered including longer shackles.
Post Posted: Thu Jan 17, 2013 6:02 am
Dammit ok thanks
Hey have you still got the fuel pump pin?
Post Posted: Thu Jan 17, 2013 6:04 am
That wasn't me.
Post Posted: Thu Jan 17, 2013 6:07 am
Oh sorry that was for hooki
Vehicle: 1984 NT High Top
Post Posted: Thu Jan 17, 2013 9:55 am
So Jake. Your not a troll.
Interesting
Post Posted: Thu Jan 17, 2013 12:23 pm
wow, just wow!!! i am gobsmacked... thought for sure he was a troll bit it appears he's legit. http://www.gumtree.com.au/s-ad/maddingt ... 1012207396
Post Posted: Thu Jan 17, 2013 1:10 pm
No not a troll
Post Posted: Thu Jan 17, 2013 1:42 pm
Just someone who can't post pictures apparently.
Post Posted: Thu Jan 17, 2013 1:58 pm
So Jake you have a mobile number, can you use it to send pics??
Post Posted: Thu Jan 17, 2013 2:05 pm
Yeah but I proffer to email
Post Posted: Thu Jan 17, 2013 2:06 pm
If you can email champ you can post on this forum and help people to help you.
Post Posted: Fri Jan 18, 2013 1:58 am
In W.A we have different laws.
IIRC you're allowed up to 50mm of lift, 15mm of that can come from an increase in tyre size. So you're allowed to have a 30mm increase in tyre diameter provided you have 35mm of other lift, or less.
Aside from a lack of diff clearance, stock tyres are the best for sand, having said that mine went pretty well anywhere on sand with 30x9.5s but the power lost turning such heavy tyres really sucked.
A Suzuki's biggest limitation on sand is a lack of power, don't make it worse by fitting larger tyres.
Post Posted: Fri Jan 18, 2013 2:03 am
Ok looks like I should also get a turbo haha :lol:
Post Posted: Fri Jan 18, 2013 2:18 am
Oh fuck, what have I done?!!
Post Posted: Fri Jan 18, 2013 2:21 am
Haha :lol:
Vehicle: sj51
Post Posted: Fri Jan 18, 2013 5:29 am
Get 205/50/15 tyres for it... it will exactly like fitting a turbo
Users browsing this forum: No registered users and 105 guests
