It is currently Thu Nov 05, 2026 8:55 am
Vehicle: Swb vitara
Post Posted: Wed Mar 27, 2013 3:47 pm
Anyone know or who can push sealed bearings on to vitara axle cheap ? Brisbane north are
Post Posted: Wed Mar 27, 2013 3:49 pm
any one with a press. im located ipswich so might not be an option for ya
Post Posted: Wed Mar 27, 2013 4:12 pm
I took mine to a local small mechanic.. He had it done pretty quick for 40 odd clams.. Prob only took him a minute to do, but he did get it done quick without having to book it in or anything :)
Vehicle: 86 SJ413 dings / rust / 30's
Post Posted: Wed Mar 27, 2013 4:18 pm
The bearing "can" be bashed on with some thick walled pipe, its the locking collar that goes behind it that as I understand it needs a little heat from a oxy / lpg plant / oven?? to chuck on behind it.
Yes I have done some and used a press for the bearing (I havn't measured but must be a size for size or vfkn close) and the collar "must" be .01 under - have heated them up and "chucked" them on...
Post Posted: Wed Mar 27, 2013 4:27 pm
viewtopic.php?t=8728
In this thread they've popped the axle in the freezer for a cpl days and lightly oven baked the bearings to put them on.. That's a cheap way!! Can't testify how effective it is, I haven't tried it :)
Post Posted: Wed Mar 27, 2013 5:41 pm
if at work , i will heat a block of steel with the oxy, sit shrink ring on this for a while, then fit.........with a bit of pipe (quicker and easier than using the press).
If at home, bit of flat bar on the stove top, and put shrink ring on that, just takes a bit longer to heat....then do the same.
Post Posted: Wed Mar 27, 2013 10:28 pm
Grind them off, press them on
Never had to heat/cool
Post Posted: Wed Mar 27, 2013 10:35 pm
X2.
PM'd.
Post Posted: Thu Mar 28, 2013 10:15 pm
99% of the time this is right.
Had a problem with a mates 70's Celica yrs ago, supplied shrink rings moving......fitted cold and hot. Ended up taking a light cut on the axle and making 4140 rings with something like .006" interferance. Heat shrunk on......they didn't move.
Tho very rare, and never seen it with a wheel brg, i have seen a bearing crack the inner race from cold fitting to a pump shaft. It was not seen on assembly and lasted maybe 5hrs before it, and the the pump destroyed itself......Sumitomo 7T excavator, big $$$$ repair bill.
Post Posted: Fri Mar 29, 2013 11:10 am
Had a hell of a time pressing mine on. Didn't help that the backing plate made it difficult to support it.
Post Posted: Fri Mar 29, 2013 11:21 am
X2.
X3.
Users browsing this forum: Google [Bot] and 22 guests
