It is currently Wed Nov 04, 2026 11:02 pm
Post Posted: Sat Apr 20, 2013 7:15 pm
Hi guys, normally I would research the crap out of my problem and then start trying to figure out a solution myself. But I'm in Coffs for a weekend of wheeling and i don't want to spin spanners on the zook/waste everyones time while i could be out wheeling.
The car is throwing a CEL and stuttering when it does. It only happens when underload and below 4500RPM. Above 4500RPM it's fine and has no stutter. It's also effected by throttle control. If I am into it and it throws the code I back of the throttle a touch and it disappears but when I push back down it comes on again...
It only started happening after some 6000RPM attempts at a super steep clay hill climb.
I was thinking the cam sensor might have oil in it from being rev'd on such a slope?
I need to drive home on Monday and tow my trailer 450kms.
I really appreciate all your help.
Wilso :D
Post Posted: Sat Apr 20, 2013 7:20 pm
stutters missfires or stutters like a Sierra would have crap in the carby?
The LJ was doing that, was a blocked hose between manifold and map sensor, prick of a thing that I would never have found if it wasn't mentioned here
Post Posted: Sat Apr 20, 2013 9:01 pm
Yeah like the coil is breaking down.
I'll check that in the morning. Thanks Royce.
Vehicle: Jimny '09 Manual
Post Posted: Sun Apr 21, 2013 6:59 am
I would be putting my money on the coil too, not saying that that is right but its where I would look first, then cam, map sensor etc.
Post Posted: Sun Apr 21, 2013 7:29 am
if its a miss, tape up the plug tubes
Post Posted: Sun Apr 21, 2013 7:36 am
I'll try all this.
The only reason I think that it's a cam sensor is it stops doing it after 4500Rpm. Not like around there, it's as soon as it clicks over it just changes immediately.
From 4500-8000 it's pulling hard and clean with no miss.
Post Posted: Sun Apr 21, 2013 7:52 am
it might be whatever sensor is buggered the ecu ignores at 4500rpm
cam sensor should play havoc all the time as the engine needs it to run
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Apr 21, 2013 10:30 am
We got it :) there's an orange valve on the back of the intake that connects to the map sensor?? And it was clogged with oil... Cleaned her out and the goat is loving life again :D Armsup
Post Posted: Sun Apr 21, 2013 11:27 am
Thanks Royce :D
Post Posted: Sun Apr 21, 2013 1:42 pm
hmmm, orange valve?
thats not the pcv valve is it?
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Apr 21, 2013 1:49 pm
Nah not the PVC.
Unless tim pointed directly at it i wouldn't of seen it. It's hard to spot. There is a black tube that goes to the MAP sensorand the other end goes to the orange plug thing.
Users browsing this forum: Google Adsense [Bot] and 232 guests
