It is currently Wed Nov 04, 2026 2:13 am
Post Posted: Thu May 02, 2013 7:27 pm
Did a search but its very confusing to sift through all the chat in the posts to find the answers.
What Engine oil do you use in the 2.5V6 Grand Vitara.
Please keep chat to a minium.
Post Posted: Thu May 02, 2013 7:38 pm
I use 5w40 because apparently that doesnt clog up your timing chains and cause the rattle. If this is correct or not, i dont know.
Post Posted: Thu May 02, 2013 7:48 pm
Penrite recommend HPR10.
http://www.datateck.com.au/Lube/PenriteAus/
Post Posted: Thu May 02, 2013 8:26 pm
I've got Penrite HPR5 (5W-40) in mine at the moment.
Post Posted: Thu May 02, 2013 8:51 pm
Ive been using Nulon 10w40 and its started to get bad timing chain noise. Time for a flush and some better quality oil and filter.
Post Posted: Thu May 02, 2013 9:03 pm
Same here. Quiet as a mouse. Except the 2.5inch exhaust.
Post Posted: Fri May 03, 2013 8:51 am
Mobil 1. 5/40
Post Posted: Fri May 03, 2013 5:37 pm
It also depends on your climate. When I lived in Melbourne I used Castrol 5w30. When I moved to Sydney it was too thin and was consumed it quickly. I changed to 10w40 and it was much better - reduced consumption etc.
Post Posted: Fri May 03, 2013 8:06 pm
Might give Penrite 5W40 a go after i give it a good flush.
Apart from genuine what other makes of filter have the non return thingo?
Post Posted: Fri May 03, 2013 10:15 pm
I just started using castrol magnatec - 10w40, virtually no rattle. Was using castrol 15w40 previously and it rattled a little more than it does now.
Not too sure about filters...i thought they all had that anti drain back value thingy
Post Posted: Sat May 04, 2013 5:50 pm
In my other thread there is talk of using Deisel oil due to its cleaning properties..... Might be a goer for keeping things clean.
Post Posted: Wed May 08, 2013 6:36 pm
Dropped some Penrite HPR5 (5W40) in it and the after doing a lifter bleed (2000rpm for 20mins) it all seems good. Still have a little bit of rattle but ill see how it goes after some driving. Plan to drop the oil again in 2500kms a d stick with penrite oil. Its rated for petrol and light duty Diesel motors so has the cleaning detergents in it.
Post Posted: Wed May 08, 2013 7:04 pm
Put the same in my h20a on the weekend as well, pretty much got rid of the timing chain rattle except just after start up before its warmed up
Post Posted: Tue Jun 25, 2013 1:55 pm
So hpr5 would suit a h20a living in Brisbane?
Post Posted: Tue Jun 25, 2013 4:08 pm
Should be perfectly fine......
Im going to go back upto HPR10 next change. I think the HPR5 is a bit thin and is creating some lifter noise.
Post Posted: Tue Jun 25, 2013 4:34 pm
i agree with that B4T, i run a 10/40 as i reckon the lighter stuff was too thin.
Post Posted: Tue Jun 25, 2013 5:08 pm
Crankcase
PREMIER LITE 10W/30
Service Refill Capacity: 5.5* Litres (see note 159)
Manual Transmission
EP MULTIGEAR 75W/90 GL-4
Service Refill Capacity: 2.7 Litres
Automatic Transmission
AUTO TRANSMISSION FLUID (DX3)
Service Refill Capacity: 2.5 Litres
Differential
EP MULTIGEAR 80W/90 GL-5
Service Refill Capacity: 2.2 Litres (see note 15)
Power Steering
4WD Transfer
Service Refill Capacity: 1.7 Litres
4WD Differential
Service Refill Capacity: 1.0 Litres
NOTES
Includes Oil Filter
15
Rear differential.
159
If operating consistently above 30 deg. C, use SEMI SYN 10W/40 SL/CF, PREMIER 15W/40 or PREMIER 20W/50.
Post Posted: Tue Jun 25, 2013 5:58 pm
I might take it back and change it tomorrow if that's the case.
Post Posted: Tue Jun 25, 2013 6:06 pm
5.5l with filter sounds like that spec list is for the J20a 4cylinder NOT the H20/25a V6 as the refill capacity is 6.0l with filter.
Post Posted: Tue Jun 25, 2013 7:16 pm
Nope here at the specs for the J20a engine
Crankcase
PREMIER LITE 10W/30
Service Refill Capacity: 5.2* Litres (see note 159)
Manual Transmission
Service Refill Capacity: 1.5 Litres
Differential
Power Steering
4WD Transfer
4WD Differential
NOTES
Includes Oil Filter
15
Rear differential.
159
This is for
Commercial Vehicles - Light/Medium & 4WD
SUZUKI
Grand Vitara 4x4, 2.0 Litre Eng. (1998-2005)
The first listing is for
SUZUKI
Grand Vitara V6 4x4, 2.5 Litre Eng. (1998-2006)
http://www.datateck.com.au/lube/Hi-TecAus/default.asp
Dave
Post Posted: Tue Jun 25, 2013 7:22 pm
shit hey, i stand corrected!!!
i was sure it was 6l with filter... might explain my weeping rear main. :oops:
Post Posted: Tue Jun 25, 2013 8:02 pm
The best thing about my supplier is that have a tech bloke that I can ring up and he will work out if I can put a certain oil in a car and meet specs. There was a fuecked up Ford in the workshop yesterday that needed some specific synthetic oil that I had to order in like the stupid volkswagen shitboxes that take specific blended volkswagen oil :p
Vehicle: LJ80
Post Posted: Tue Jun 25, 2013 8:58 pm
another vote for 5w40 penrite.
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Tue Jun 25, 2013 11:07 pm
I use penrite hpr10. Great oil with no problems. Only use a genuine filter as experienced rattle with a ryco.
Post Posted: Wed Jun 26, 2013 3:50 am
Same here in my wife's 2.7. I have tried a few different oils to minimise rattle on start and towards the end of service interval, and the Magnatec is noticeably better (no chain rattle at all). I mostly use a Suzuki oil filter although have also used Ryco from Supercheap on occasions without noticing any difference. This is in Sydney so may be different in cooler climate.
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Wed Jun 26, 2013 6:12 pm
i did allot of research on this after buying mine with a bad rattle and the intention of fixing it (IE new timing chain kit) however i used a proper engine oil flush which i added to the warm engine aloud the engine to idle for 10 mins giving it the occasional rev to about 3000rpm just a fluctuation and then promptly drained the oil (still hot).
my research told me to run 5W30 and thats what i put in
my research told me to ditch the crappy ryco filter the reason behind this is they allow back flow of oil and prevent the hydraulics in the timing chain tensioner from working correctly.
i replaced it with a genuine suzuki oil filter i got from the dealer at $15.
the engine now runs much quieter and and is getting better after every drive.
my mechanic has now instructed me not to worry about the timing chain until it starts getting louder as it is nearly not present atm (just idles like a diesel truck ;) )
this is in the H20A but is essentially the same motor exempt the bore/stroke.
Vehicle: Jeep
Post Posted: Wed Jun 26, 2013 7:20 pm
I use Valvoline Durablend 10W40 Semisynth, its made for engines under loads, and 4WD's, its not cheap, about $47 for 5L, but gives me extra piece of mind...
+1
For the Genuine Oil Filter, they used to be $40, but have come down to $15 now, and they do quieten timing chain noise, or remove the noise completely, like it did with my GV... :D
Vehicle: SV620
Post Posted: Wed Jun 26, 2013 10:23 pm
Sorry I beg to differ H20A from the SV620 manual and I quote "oil pan about 5.5, oil filter about .4 other .6, total about 6.5 liters" the last time I changed mine it took allmost that but I do wind it over a few times after removing the oil filter with injection off to get as much of the old oil out then do the same when filed up before I start it. As for type of oil 5W-40W full synthetic as I have seen first hand the crap non synthetic leaves behind.
Vehicle: Suzuki Grand Vitara
Post Posted: Tue Jul 02, 2013 1:39 pm
Seems my post was deleted over the last forum shut down.
Has anyone used DELVAC? Its a diesel oil and is meant to be very good.
Users browsing this forum: No registered users and 391 guests
