It is currently Thu Jul 23, 2026 6:09 pm
Post Posted: Tue Jul 28, 2009 10:42 pm
just put on a new case due to cracked one. and i cant figuar out where the 3 little steel balls go. ive read the trail creeper transfere case rebild and i can only see 2 dent balls.
so where the fuck does this 3rd one go?
navara on 33s. hopfully rear air locker soon
Post Posted: Tue Jul 28, 2009 11:04 pm
it has been ages since i done mine bit over a year.Not something to do with 4wd light switch is it???apart from that i have no idea mate.
Post Posted: Tue Jul 28, 2009 11:14 pm
Put one ball in first with spring. Than fit the rod. Than fit second rod. Than fit last ball externally. Leave the middle ball out.
You will than Have the ability to select 2low.
Very handy.
Search 2low mod for more info
Post Posted: Wed Jul 29, 2009 2:44 am
Are you sure? This is how I did it. Spring,ball, 4wd shifter fork,ball,low/high shifter fork,ball,spring then plug. To put the 1st ball in I had to use. Screw driver to hold the ball down while I put in the shifter
Post Posted: Wed Jul 29, 2009 2:37 pm
http://www.trail-gear.com/tech/zuk65gears/index.html
Post Posted: Wed Jul 29, 2009 9:54 pm
if you read my first post you will see that i said i have read that. anyway that only shows the 2 balls.
Post Posted: Wed Jul 29, 2009 10:14 pm
That's correct.
Leaving the middle ball out is an option though.
What's the problem? It sounds like you've done it right.
Users browsing this forum: No registered users and 236 guests
