It is currently Thu Sep 24, 2026 8:15 am
Vehicle: Suzuki Vitara JLX 1991
Post Posted: Wed Jul 24, 2013 10:23 pm
Hi Folks,
Drained the trans fluid a few months back. Refilled it and used teflon tape and what appears to be a drain plug leak? Dropped the oil last week and used permflex type blue sealant and re filled the trans case. Bloody thing is still leaking. I dont see any other leaks on the trans. I did change the rear tail shaft seal last year and there is no oil there and is now bone dry.
I have filled up my diffs(front/rear), Transfer Case and have no leaks from those.
is this a common issue? Can you buy a better drain plug that will fit and maybe have a rubber gasket? Something like this? -------->http://www.ebay.com.au/itm/Suzuki-engine-plug-many-application-oil-head-transmission-77-10-oem-09247-14012-/190720362242?pt=Motorcycles_Parts_Accessories&hash=item2c67d1c702
Jason
Post Posted: Wed Jul 24, 2013 10:31 pm
Case isn't cracked from over tightening?
Post Posted: Wed Jul 24, 2013 10:36 pm
Not that I can see mate. It looks pretty good. I might check tomorrow when I have more of a chance in better light. I just cant seem to stop the drip leak.
Vehicle: 85 ' Drover
Post Posted: Thu Jul 25, 2013 7:56 am
I cant recall the design of the drain plug, but does it have a washer?
Sometimes they are a material type stuff, which in my experience after a few yrs become a bit useless and tend to seep oil. A new copper washer of the proper size will work wonders, and if you are careful is reusable.
Post Posted: Mon Jul 29, 2013 8:05 pm
nah pretty sure they a tapered thread.
Users browsing this forum: Google [Bot] and 63 guests
