It is currently Fri Sep 25, 2026 7:13 pm
Post new topic Reply to topic  [ 198 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
Vehicle: 96 V6 Vitara
Post Posted: Wed Jul 24, 2013 8:44 pm
yer DW i killled it haha snaped camshaft. o well wont be rebuilding that motor. anyone want a H20a boat anchor? haha
Post Posted: Wed Jul 24, 2013 8:47 pm
over it now. so the cranking the engine with the bar against something works on these too! thats cool. ill have a go at the one in the car when i get it back from mechanic maybe tomorrow...
Post Posted: Wed Jul 24, 2013 8:49 pm
8O butcher :lol:
Post Posted: Wed Jul 24, 2013 9:10 pm
LOL meh im over it. was dead anyway, was going to pull it down and see if it was worth a rebuild but not any more haha
Post Posted: Thu Jul 25, 2013 10:01 pm
Ok so progress on timing chain replacement. made another video so thought id put it here. The mechanic was kind of a waste if time but hopefully fixing these chains and tensioners will sort it out and i can finally start to enjoy my little vitara!
http://www.youtube.com/watch?v=OIMzg0GV ... e=youtu.be
Post Posted: Thu Jul 25, 2013 10:50 pm
AZ represent Armsup
nice work on getting it apart & cheers for the effort in putting a vid together. :wink:
Post Posted: Thu Jul 25, 2013 11:03 pm
no worries i should have done some along the way but its pretty straight forward really. If you can get to this point i dont think you should be trying to do your own. But its there if it helps anyone. :peaceout:
Post Posted: Thu Jul 25, 2013 11:06 pm
oh yeah, your dog looks like a wookie Image
Post Posted: Thu Jul 25, 2013 11:11 pm
hahahaha i know hes awesome! He just had a hair cut, you should have seen him before it!! He gets Ewok a fair bit too lol and teddy bear. Hey if you want to put my video in a better place im not a forum buff so dont know if it should be in another thread or something, but feel free if you think its useful at all to move it.
Vehicle: SV620
Post Posted: Fri Jul 26, 2013 7:06 pm
A word of advice and this is speaking from experience. The cam chain tensioner has a one way valve and should not leak and keep the chain tight motor runing or not. Why do I know this because I put an after market kit in mine and it ran fine for about 15 min and then started to rattle again and it was a dud cam tensioner one way valve. So it was striped down again to replace it with a Suzuki one. You can test them by pumping oil in to it and you should not be able to push it back and it should not leak out the one way valve or any wear else for that mater..
Post Posted: Fri Jul 26, 2013 7:49 pm
OK cool. im assuming your talking about the on on the right hand cams? the under the chain? i have some more videos to put up, just waiting on them to upload.
Post Posted: Fri Jul 26, 2013 8:07 pm
http://www.youtube.com/watch?v=l7p5tlp5 ... e=youtu.be
Next video.
Post Posted: Fri Jul 26, 2013 8:12 pm
http://www.youtube.com/watch?v=nlicBSo7 ... e=youtu.be
And the follow up.
Post Posted: Fri Jul 26, 2013 9:05 pm
Some nice tarnish going on in there!
Post Posted: Fri Jul 26, 2013 9:16 pm
Meh lol looks colourful! Armsup
Post Posted: Fri Jul 26, 2013 9:18 pm
doesn't look like a low km engine that's had regular servicing :?
Post Posted: Fri Jul 26, 2013 9:49 pm
There is NO one way valve in the tensioner to keep oil in - it is a purely mechanical "ratchet" type affair - I'm not doubting that you had a problem with a dud one, but it does not trap oil inside, oil drain back IS a problem, and that's why they rattle at start up before the oil pressure comes up.
Vehicle: SV620
Post Posted: Fri Jul 26, 2013 10:08 pm
I am talking about the one in the right hand cam bank tensioner number 2 although mine was a H20A it did have a one way valve as did the replacement from Suzuki.
Poor service and the incorrect oil I would say.
Post Posted: Sat Jul 27, 2013 12:40 am
The one on the right side has not got notches. It is one way valve/ constant pressure the other two are ratchet type. As for the tarnish I would say most look like this. I've seen inside 3 now and all the same. That said they have all been shit hahaha
Post Posted: Sat Jul 27, 2013 12:41 am
Does not have notches (terrible English)
Post Posted: Sat Jul 27, 2013 12:48 am
just watched ya new vid, definitely keep the cam caps assigned to the position they came from.
Post Posted: Sat Jul 27, 2013 10:24 am
Ok cool well they are in order. I looked at them and they have position markings on them so yes you need to keep them in order.
Post Posted: Sat Jul 27, 2013 1:16 pm
My H25a arrives on Monday. I've been told by the mechanic at suziauto to run h25 from rocker cover to sump and h20 everything else. Basically bolt the h20 intake onto the bare h25.
Is that what's worked best for everyone else?
H20 injectors?
Post Posted: Sat Jul 27, 2013 1:58 pm
i know this thread is now 6 pages long, but did you read any of it? :?
Post Posted: Sat Jul 27, 2013 3:03 pm
Yeah Atari is right BUT i will help you out. If you have a H20 and putting a h25 in, bolt everything from the h20 onto the h25 block and head. EVERY THING!!!! including the cam position sensor on the back of the left hand exhaust cam. EVERY THING!! even the water inlet to the block! Its easy. ull be fine.
Post Posted: Sat Jul 27, 2013 3:09 pm
Yes I've read it a few times over but i was just double checking.
Thanks murpha
Post Posted: Sat Jul 27, 2013 3:20 pm
No worries, any other questions ive done the conversion twice now as you can read from the posts haha :lol:
Post Posted: Tue Jul 30, 2013 1:48 am
Ok las videos before i fire it up. Still waiting on the water pump :shocked:
http://www.youtube.com/watch?v=JO_XB5QPwQQ
Post Posted: Tue Jul 30, 2013 11:25 pm
Ok all done! Finally! this is just the first start after the timing chain is finished. It has a little bit of a miss but that could be the fact that the mechanic broke the connector on one of my coil packs.... And rather than replace it of offer a discount or anything they just said to me "oh you have a broken coil" which wasn't broken before i took it in to them... Well again i stick buy, If you want something done, Do it your self. If you want something done properly, Take your time and do it your self. Don't think I will ever take my cars to a mechanic ever again. (sorry if offend any mechanics) but the number of times they are either useless or a rip off or just plain don't want your business, Im over it.
Any way rant over. I hope these videos have been helpful.
http://www.youtube.com/watch?v=du_nXwQ8elo
Post Posted: Tue Jul 30, 2013 11:39 pm
good shit Armsup
Users browsing this forum: No registered users and 93 guests
