It is currently Sat Aug 01, 2026 2:15 pm
Vehicle: 98 Jimny
Post Posted: Sat Jul 06, 2013 10:48 pm
Hi i am going to buy 6.5:1 Sierra reduction gears for my jimny.
I need to buy a 1.3L sierra T/case just wondering what type of sierra t/case will best fit this http://locktup4x4.com.au/sierra-6-5-1-r ... s-391.html ???
and do i need a driveshaft spacer??
Post Posted: Sun Jul 07, 2013 12:20 pm
what size of tyres are you planing to run?
6.5 gears are way too low for a jimny, the % of reduction doesnt apply in the same amount for jimnys than sierras do.
have a look in here viewtopic.php?f=5&t=22383
Post Posted: Sun Jul 07, 2013 12:59 pm
6.5s will equal 37s for decent ish highway speed...
Vehicle: 98 Jimny
Post Posted: Sun Jul 07, 2013 5:20 pm
I am planing on putting 31s
what about the 4.5??
Post Posted: Sun Jul 07, 2013 5:37 pm
Stock sierra gears on 31s then
Vehicle: 98 Jimny
Post Posted: Tue Jul 09, 2013 2:18 am
what do i need to fit a sierra T/case to the jimny???
1. Shaft Spacers??
2. front and rear tail shafts??
3. does it matter if its a W/T or a N/T and what is W/T (wide track??) and N/T (narrow track???)
Post Posted: Tue Jul 09, 2013 8:52 am
viewtopic.php?f=17&t=30820
Post Posted: Wed Jul 10, 2013 8:28 pm
1L transfer for 31s
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Wed Jul 31, 2013 7:14 pm
1L transfer for 31s
I thought the 1l transfer didn't fit. 8O
Post Posted: Wed Jul 31, 2013 9:08 pm
whats needed to fit a 1l transfer to a jimny?
Post Posted: Wed Jul 31, 2013 9:25 pm
Asps91 wrote:
1L transfer for 31s
There's two types, one has a 4WD light switch and is the same housing as 1.3L transfer. Flanges need to be swapped.
Post Posted: Wed Jul 31, 2013 9:30 pm
Same as fitting a 1.3 transfer
http://www.auszookers.com/forum/viewtopic.php?f=5&t=22832
Post Posted: Thu Aug 01, 2013 12:47 pm
can the non switched 1l transfer be fitted?
Post Posted: Thu Aug 01, 2013 1:02 pm
not by the sounds of this:
Asps91 wrote:
1L transfer for 31s
Post Posted: Thu Aug 01, 2013 1:56 pm
I don't know, Fatzook would know for sure. If the dimensions and mount points are the same I would imagine it would but you'll never get the 4WD light in your instrument cluster to work.
Post Posted: Thu Aug 01, 2013 1:58 pm
Also, the WT flanges may not fit the splines on a no switch transfer
Post Posted: Thu Aug 01, 2013 2:12 pm
A non switched case will theoretically fit. The mounts are the same but you'l have to do something about the flanges as they can't be swapped to 1.3l ones. There's also no aftermarket gear options for them, unless you can dig up an up geared set from the early 80s.
Users browsing this forum: No registered users and 256 guests
