It is currently Tue Nov 03, 2026 4:58 pm
Vehicle: 94' part 'OCD' sierra
Post Posted: Mon Aug 05, 2013 7:32 pm
tried finding a replacement part but could only find this;
http://www.lowrangeoffroad.com/index.ph ... -body.html
Can you get this in Aus?
If not what have others used instead?
This for a 94 sierra rebuild sorry.
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Mon Aug 05, 2013 8:50 pm
i removed mine, just used a blade to take it off. i will just use some black silicone to fix it back on
Post Posted: Mon Aug 05, 2013 11:35 pm
Suzistore:
http://www.suzistore.com.au/onlinestore ... etail.html
Post Posted: Mon Aug 05, 2013 11:41 pm
he's after this bit
Post Posted: Tue Aug 06, 2013 5:49 am
Go to Bunnings or Masters etc and buy a strip of sticky back foam in 50x 5mm and trim to size.
Post Posted: Tue Aug 06, 2013 7:38 am
Thanks for that want33. That's what I was after.
Cheers again.
Post Posted: Tue Aug 06, 2013 9:57 am
I would advise against this as all the foam cell I have used has eventually wicked with water and started leaking when you drive in wet conditions. Rubber strip would be a better alternative. Bunnings has that sort of stuff.
Post Posted: Tue Aug 06, 2013 4:53 pm
Good quality high density foam won't absorb water.
Vehicle: Daisy
Post Posted: Wed Aug 07, 2013 6:43 am
I used some black high density foam from foamworld or whatever the place is called, I told them exactly what it was for and they said the same as want33s.
Rubber or foam, take your pick, don't make it too thick though or you will have issues with that as well, and make sure you go right across and then along the bits that come back towards the cabin a little bit, otherwise it will pour in there instead.
Post Posted: Wed Aug 07, 2013 10:13 am
Same story I heard from the clark rubber stores I went to. Ended up with high density neoprene foam tape, 5mm thick. Drive up the highway in heavy rain for an hour or so and it eventually wicks through it's cells. Same with the eva "closed cell" foam tapes or what ever else they sell.
I initially thought it was just leaking between the foam and the windscreen surround, so once it started leaking I pulled the windscreen frame and found the foam tape to be saturated. Run your finger over it and water streams out.....
I'm now using this sponge seal http://www.clarkrubber.com.au/rubber-an ... -seal.html the whole outside of the seal is fully closed. No more water wicking issues and a dry car :D
Post Posted: Thu Aug 08, 2013 8:37 pm
Yeah thanks again guys. Went the high density like advised. Cheers
Users browsing this forum: Google [Bot] and 404 guests
