It is currently Tue Oct 20, 2026 9:00 pm
Post Posted: Sat Aug 01, 2009 11:38 am
Hey all last night I went for a bit of a drive to take some pics of the flex with the wide track diffs etc.. was driving down a small track in 4WD and went to knock her into 2WD and got locked out of all gears :( Now it's floating in no mans land (Neutral). I tried rocking the car back a forwards etc.. but couldn't get it to un-jam managed to get her to a mates nearby but going round today to fix her in the light. My question is what is the best and easiest way to resolve this problem and what would be the cause and solution to preventing this happening? All help apprieciated Thanks in advance Cheers Robb.
Bitumen...Another waste of public funds!
Post Posted: Sat Aug 01, 2009 11:45 am
1. Remove shift lever
2. Realign shift rods
3. Replace shifter bush
4. Replace shifter
5. Go zookin'
Post Posted: Sat Aug 01, 2009 11:53 am
Thanks Damo. Should I replace anything in the future to prevent this?
Post Posted: Sat Aug 01, 2009 12:13 pm
No need for further reply I just relised someone else is having this same problem but didn't see the post cause it was down the page. Cheers Robb.
http://www.auszookers.com/index.php?nam ... pic&t=5797
Vehicle: MY2019 Jimny
Post Posted: Sat Aug 01, 2009 3:56 pm
4. Replace shifter
5. Go zookin'
Post Posted: Sat Aug 01, 2009 4:07 pm
it's the shifter bush, they all do it, mine did it half way up a hill was fun rolling backwards down a steep hill in neutral with front and rear drum brakes
Post Posted: Sat Aug 01, 2009 4:56 pm
Thats Nasty! thank God I have Wt Diffs with discs now!
Post Posted: Sun Aug 02, 2009 2:54 pm
Pulled her apart yesterday just popped the shifter out and the bush was screwed! (all crumbled) and shifter had dropped as a result, so cleaned her all out & will drain all oil and replace with new bush. We realigned the rods but now waiting on a bush to finish the job.
Anyone know where I can get a shifter bush on a Sunday in Eastern Suburbs Melbourne?
Cheers Robb.
Post Posted: Sun Aug 02, 2009 2:59 pm
sounds like your out of luck, but i will hit bruce up for a poly one, you won't find a non genuine one anywhere else anymore
Users browsing this forum: Google [Bot] and 221 guests
