It is currently Sun Apr 19, 2026 1:31 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
Post Posted: Wed Aug 14, 2013 9:44 am
Why
Picked up a bundy housing and axles for $100, still need to find a front complete unit though
1- I've been toying with this idea for a while, and just decided 'why not' and 'because I can'
2- Blown two rear centers while towing my trailer, and a transfer case (upgraded to a Sierra transfer now)
3- Also hoping the added 'bulk' in the front might get rid of my 'Jimny wobble' which I've tried everything to fix
4- my Jim has already been blue plated for front and rear axles when it was plated for the turbo kit.
5- if I decide their not for me in the end I will always be able to sell them for what they owe me
What's the car used for
I mainly do beach work so I'm not after crazy flex, I also tow a medium sized trailer 80% of the time and when we go camping. I have a heavy foot and like boost.
The plan
To have both complete axles looking as close to the Jimny axles as possible, ie copy brackets and everything etc.
keen to take my time too.
Planned -Rear
- disk conversion
- shaved and armored pumpkin
- shortened housing (approx 30mm)
- heavier duty brackets
- re-drill axles back to suzi 5 stud
- use Jimny front disks
- dash fitting for breather
- new RD132 air locker
Planned -Front
- shortened housing
- 7deg pos caster
- rotated pumpkin
- braced knuckles
-Tail shafts? Was going to run these LowRangeOffroad flanges,
http://www.lowrangeoffroad.com/index.ph ... lange.html
Cost of parts (will keep updating)
- $100. rear housing
- $160. Toyota/Suzuki pinion flanges + Russell speed bleeders
- $20. New 1.5 pitch wheel nuts
- $34. New rear wheel studs
- $120. Axles re drilled to 5 stud
- $50. 4:1 High pinion Toyota 80series (super cheap find)
Sorry for the crappy ipotato photos
Stripped down the housing
Huge axles
Cut brackets off with the plasma cutter
Stripped axles ready for re-drilling and checking disk fitment, thinking of using Jimny front disks, trying them on tonight
Diff flanges and Russell speed bleeders turned up today
New 1.5 pitch wheel nuts to suit the Toyota studs $20, way cheaper than changing studs
High pinion 8" 4:1 out of an 80series cruiser front
Last edited by kyzermattingley on Tue Sep 10, 2013 1:12 am, edited 8 times in total.
Post Posted: Wed Aug 14, 2013 2:48 pm
Set yourself up a vat of Molasses and drop your parts in, to remove rust. Can take a week or 3 but does a fantastic job, and its very cheap.
Post Posted: Wed Aug 14, 2013 6:35 pm
Lovely work mate. I was too contemplating this before I ended up selling my turbo lwb. Can't wait to see how it ends up.
Post Posted: Wed Aug 14, 2013 9:02 pm
Have never heard of this, will just get the housing sand blasted I think, good to keep in mind for another project
Last edited by kyzermattingley on Wed Aug 21, 2013 12:40 pm, edited 1 time in total.
Post Posted: Sat Aug 17, 2013 9:58 am
This is going to be awesome. Are you going to use hilux drive shafts so you get stronger uni joints?
Looking forward to seeing the updates.
Post Posted: Sun Aug 18, 2013 8:02 pm
At this time I was going to use the Sierra shafts, if I find that they fail ill change to Toyota shafts, if I run these
Pinion flanges I can just bolt everything up and at $29 ea they are cheap
Post Posted: Sun Aug 18, 2013 8:11 pm
I decided on custom shafts in mine in the end... much stronger, and i'm running hilux double cardans at the tcase end (ie: bulletproof) - the other ends of my shafts (the splined ends) are interchangeable - so if i break a rear uni (suzuki uni so its the weak link) i can swap it with the front and continue in rear wheel drive to get home, rather than being stuck in front wheel drive.
Post Posted: Mon Aug 19, 2013 8:21 am
Was going to say, keep the uni's as the weakest point in the drive line. Cheap and easy to replace.
Post Posted: Mon Aug 19, 2013 9:50 am
uni's might be easy to replace- but when they pop- they can do horrendous damage.
Many years ago, I dropped a rear propshaft uni, [the front universal joint] and shattered the extension housing of my gearbox / bent the output shaft.
I was damn lucky the propshaft didnt drop off and dig into the road.
If you are going to give your uni's a hard life- replace them before they fail.
if possible- fit driveshaft loops so you can catch the shaft before it breaks free.
stephen
edited to fill in detail :?
Post Posted: Mon Aug 19, 2013 10:26 am
^^ Thats why i've got a hilux double cardan at the tcase ends, so if its going to let go, it will do it at the diff ends - which are made the same front and rear so they are interchangable =)
You are right though, last time i broke a uni (the only time) when it let go it bent the lobes that hold the uni, so it wasnt as simple as just replacing uni joint, i needed a new shaft made basically.
Post Posted: Mon Aug 19, 2013 5:18 pm
Still cheaper then a diff or a transfer case.
Front shafts are an issue as you can't fit loops to prevent the front dropping down.
Post Posted: Wed Aug 21, 2013 12:39 pm
I'm going to follow the current trend and add all photos etc to my first post, will get some more work done tomorrow night
Kyzer
Post Posted: Tue Sep 10, 2013 1:15 am
Still after a Bundera Front if someone knows of one somewhere
Post Posted: Tue Sep 10, 2013 8:03 am
Try outerlimits?
Post Posted: Tue Sep 10, 2013 8:13 am
alien wrote:
Try outerlimits?
Just signed up, fingers crossed, would like to get one before I go on holidays in 2weeks
Kyzer
Post Posted: Wed Sep 11, 2013 8:14 pm
I have a bundera front housing
Post Posted: Wed Sep 11, 2013 8:15 pm
It's just a bare housing tho
Post Posted: Wed Sep 11, 2013 8:36 pm
Don't use Bundera front. Use Hilux. Same shit but dirty30's or longfields fit.
The pumpkin centre is more in the middle with a bundy front.
Or if you super bundy keen. I have axles here to post. You will not be able to redrill the front hubs. Just the way they are designed. Try get vented discs and calipers. All hilux/bundera solid axle parts interchange easily
Post Posted: Thu Sep 12, 2013 11:23 am
Ok so now thinking of using LUX front housing with BUNDY steering arms, with my 80series 4.1 and I'll make all the rods, thanks heaps for the advice guys.
Kyzer
Post Posted: Thu Sep 12, 2013 2:13 pm
OR (just had a brain wave) I could use the lux housing and only shorten the drivers side axle and axle tube, hmmmm, wish I had all the stuff sitting at home to just measure up
Last edited by kyzermattingley on Fri Sep 13, 2013 8:17 am, edited 1 time in total.
Post Posted: Fri Sep 13, 2013 7:10 am
I would just use a hilux front, then parts are abundant.
Post Posted: Fri Sep 13, 2013 7:29 am
Superduki has a mate with shortened Lux duffs f&r in his wide track. So it is very achievable
Post Posted: Fri Sep 13, 2013 3:48 pm
So now chasing
- Front bundy hubs with steering arms or just steering arms
- Front bundy longside axle
- lux housing
Kyzer
Post Posted: Tue Sep 17, 2013 7:19 pm
Y do u want cut it down
Post Posted: Wed Sep 18, 2013 8:16 am
My guy will only plate it if the axles and stud pattern are the same as before.
On another note, thinking of not trussing/bracing these Toyota housings, they already seam way heavier duty than the suzi stuff, really carnt see them bending.
Bought a complete HILUX front end wheel to wheel (yes, it even came with the wheels) for $200, will set about stripping it soon, still need BUNDERA steering arms though, and would love a BUNDERA long side axle to compare to the HILUX one.
Kyzer
Post Posted: Fri Sep 20, 2013 12:27 pm
why not use 80'series steering arms/kunckes?
Post Posted: Fri Sep 20, 2013 7:55 pm
No reason, just had no experience with Toyota stuff, have found the bundy stuff I need anyway, will grab it in a week and get started, I'm off snowboarding for this week though so the car can wait
Kyzer
Post Posted: Mon Sep 23, 2013 4:24 am
Why?
Post Posted: Mon Sep 23, 2013 10:00 am
ah was just for avalability!
Post Posted: Mon Sep 23, 2013 3:33 pm
Different. That's why.
He will only need the bundy arms once.
Users browsing this forum: No registered users and 7 guests
