It is currently Sat Oct 31, 2026 4:45 pm
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Nov 17, 2013 8:44 pm
A sierra alternator is supposed to bolt straight to a baleno block yes ???
Vehicle: 4wd
Post Posted: Mon Nov 18, 2013 12:05 pm
I've never heard of anyone wanting to do that. Why not run the Baleno alt?
I don't know how much draw an EFI motor requires over a carby motor but it could be possible that a Sierra alt wouldn't be up to the task.
Watch out or you'll get sued.
Post Posted: Mon Nov 18, 2013 12:16 pm
it would have the wrong belt type. theres no reason to do it
Post Posted: Mon Nov 18, 2013 12:39 pm
My plug on my loom is sierra my pully is multi rib its just sitting crooked atm I couldn't afford to get a falcon one at the moment ...
Post Posted: Mon Nov 18, 2013 12:42 pm
you need the baleno alt, you also should be using the baleno loom, so the plug for the alt should be a baleno one.
Post Posted: Mon Nov 18, 2013 12:47 pm
Kkk loom
Vehicle: 4wd
Post Posted: Mon Nov 18, 2013 12:57 pm
Change it back.
Baleno alt and Baleno plug.
How much did he charge for the loom?
Post Posted: Mon Nov 18, 2013 1:02 pm
either way you shouldnt be using the sierra alt
Vehicle: 4wd
Post Posted: Mon Nov 18, 2013 1:08 pm
*Baleno alt.
Post Posted: Mon Nov 18, 2013 1:10 pm
Im using sierra alt but seems to not sit right ..it did on the other motor.
- Loom is fantastic very very tidy work,and it cost $550 .u actually still use the Sierra charge and start wires so thats why bolted it on.
Steve I think his name is ¿¿ @ kkk said he probably still has a plug and will post with a diagram from color to color to get me out of trouble.
Im confused why the alternator bolted to the g16a and not g16b I have to have done something tard.
Post Posted: Mon Nov 18, 2013 1:12 pm
it doesnt bolt up cos the heads are different.
so is the brackery
Post Posted: Mon Nov 18, 2013 1:16 pm
Guess ill have to wait for the right plug ...has anyone got a spare baleno plug just in case kkk cant find my old one
Vehicle: 4wd
Post Posted: Mon Nov 18, 2013 1:20 pm
Did you ask for the loom to retain the Sierra alt plug?
Post Posted: Mon Nov 18, 2013 1:25 pm
The charge system isnt part of the loom u get back..he instructs u to just use ur stock charge system and start wire .
If I knew it to be a problem I would have cut it off before sending the whole baleno loom.
U get a couple of relay blocks with a couple of fuse blocks and it just piggy backs of ur factory loom.....kinda like just wiring a steza
....1 to constant power , 1 to ignition ...fans-fuel pump ect
Vehicle: 4wd
Post Posted: Mon Nov 18, 2013 1:29 pm
Sounds like you just sent him the Baleno loom?
For that kind of money I thought you would of sent both looms and got one merged loom back.
Post Posted: Mon Nov 18, 2013 1:40 pm
I was happy with the result from him I dont have much spare time
Post Posted: Tue Nov 19, 2013 11:02 am
KEENSY85 wrote:
Kkk loom
who is kkk do you have a link
 Profile YIM
Post Posted: Tue Nov 19, 2013 11:03 am
killa kustom kables
https://www.facebook.com/#!/pages/Killa ... 85?fref=ts
Post Posted: Tue Nov 19, 2013 11:36 am
jimbo_jones wrote:
KEENSY85 wrote:
Kkk loom
Follow tanshi's link.
Pretty good to deal with ...give him plenty of time to get it done :) hes hard to get on the phone because he seems to get very snowed under but when he says its in the mail he posts it express :)
Post Posted: Tue Nov 19, 2013 11:53 am
Thanks
 Profile YIM
Users browsing this forum: Google [Bot] and 79 guests
