It is currently Thu Oct 29, 2026 3:05 pm
Post Posted: Mon Jan 27, 2014 9:28 am
Alright, so I posted this on outers but then looked at the dates on some of the other topics. WOW! It seems that place is dead, so thought I'd try here.
Good Morning all
Alright so in a bid to get the misses a bit interested in 4wding I've been keeping an eye out for any sierra's going cheap locally.
Found one sitting in a guys backyard that's doing nothing in particular, it has been rolled, but not written off. There's a bit of damage to the front clip, doors and windscreen surround/roof (it's a softtop). I've had a look see at it and seems to be withing my capabilities to be called a fixer-up. I also think it is a pretty good price, as if the misses loses interest, i can part it out and shouldn't be out of pocket any play money (that is money used to play with toys).
The biggest concern I have with it, is the intake manifold and carb have been removed and sold off. I'm told the engine hasn't been started since the roll over, and was running fine before said accident (<200,000km).
So what I'm after knowledge of anything I should be on the look out for, that if you were in my shoes you would be on the look out for?
Should I pull the sparkies out and get a breaker bar on the crank and try turn it over?
Should i be looking for water in the oil and visa versa?
I'm scratching my head to try and think of anything else, but drawing blanks.
Whatever the outcome i'm probably going to pick it up, my local wreckers have a drover with a complete intake and carb, worst case the engine's had the boot, and I swap something else into it. But if i can find something that may support damage to the engine it may give me grounds to haggle the price down more win = win.
Thanks
Also 5 years and 1 day to make my first post!
Post Posted: Mon Jan 27, 2014 10:50 am
Pull plugs and check it turns over.
There shouldn't be water in the oil or vice versa from a rollover, Worst thing I could imagine would be that the car would have kept running after the roll until it ran out of oil pressure then spun a bearing, but that should mean it won't turn over smoothly.
Users browsing this forum: Google [Bot] and 279 guests
