It is currently Fri Jul 31, 2026 4:43 am
Vehicle: Suzuki Jimny
Post Posted: Wed May 14, 2014 8:52 am
Hi all I want to get some muddies for my jimny but I will only be using them for weekends when I go off roading.
I like the BFG Muddies however I am not sure what size to buy.
My criteria:
-Gearing must be functional on the road
-I don't mind a little rubbing, the car will be 2 inch lifted but I will not chop guards.
-I want them to have good traction on anything from sand to mud
-I will also need to get a second set of rims (thinking sunrasias)
I am open to any suggestions and ideas! Please help me out!
Arin
Post Posted: Wed May 14, 2014 9:17 am
215/75r15s on the stock wheels (or wheels with stock offset) wont rub and wont need gearing. They're a tad under 28". Anything larger and life gets more difficult.
I think BFG KM2s are a great all round 4WD tyre.
Post Posted: Wed May 14, 2014 9:38 am
That's exactly what I had my eye on, I was wondering if it would be possible to get 235 in for a little bigger tire, would they rub on stock rims?
Post Posted: Wed May 14, 2014 9:54 am
235 will suck on standard gearing
Vehicle: SJ80, SE416
Post Posted: Wed May 14, 2014 10:21 am
235/75r15 on a Jimny will need a guard chop or other big modifications to fit.
But buy 235s anyway and deep rims while your at it so you can get them fitted, realise your mistake and sell them cheap...
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Wed May 14, 2014 11:50 am
If you don't want to effect gearing, go for 215's I ran them on my Jimny.
I have 3" lift and get scrubbing with 30's
TasZooks
http://www.facebook.com/TasZooks
Vehicle: Suzuki Jimny 2013
Post Posted: Wed May 14, 2014 4:35 pm
As above... 215 BFG look about the best option.
Post Posted: Wed May 14, 2014 7:56 pm
215 here too. Although if you're in an area with deep wheel ruts 235s may necessary evil but you will be best to fix the gears. I ran mine with 235s and 50mm for years with standard gearing and got by, but it did need a bit of trimming. The driving experience will be tiring and uninspiring and off-road will require a lot of mechanical sympathy. I didn't realise how bad it was until I sorted my gears for the first time.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu May 15, 2014 8:19 am
215 here too. Although if you're in an area with deep wheel ruts diff shaving may be a necessary evil
fixed it
Post Posted: Thu May 15, 2014 8:48 am
If I was only running the 235s on the weekends I go driving, do you think they are bearable?
Exactly what trimming did you do?
Post Posted: Thu May 15, 2014 8:50 am
If they aren't everyday tires and I had a 2 inch lift hwo little trimming do you think I could get away with assuming I don't mind the gearing for the 10% of the time I am using the muddies
Vehicle: 08 Jimny Type: FJB43V
Post Posted: Thu May 15, 2014 11:00 am
Sideways and Zuke are on the money with going the 215's. For no other work required to your vehicle and reliability it'll be your best/cheapest option. I have the BFG KM2 on mine with stock standard suspension, factory mags and stock gearing. 30 000 kms so far and they are going great.
About the only issue you'll find is that the muddies will dig quite hard when going through really soft sand. It's not that you'll get bogged but the front tyres will keep wanting to claw it's way from one side of the rut to the other. Mud and rock work are no problems. On steep rocky/muddy descents I've found that you'll only need very light braking occasionally to keep good control over it.
As it's my daily highway runner it's a compromise to have the comfort and economy on-road with the ability to try and keep up with the big boys on the weekend.
Another option may be to stick with your highway tyres and chuck the money on lockers. Ask Eldo, he'll tell you how far they can take ya.
Post Posted: Thu May 15, 2014 11:09 am
Should have mentioned with going the heavier tyre add in a little extra money and have the kingpins shimmed correctly.
Post Posted: Thu May 15, 2014 11:50 am
I think your thinking is the wrong way about.
With big tyres, The 99% of the time you are on the road the gearing will be fine and tyre scrubbing will be minimal.
The 1% when you are offroad enough to need 235 mud tyres on a Jimny the gearing will be at the practical limit of usable on steep climbs/descents and any tyre scrubbing is going to be worse as the vehicle articulates to its limit. It is in an off-road situation where you need your vehicle to be set-up right.
Post Posted: Thu May 15, 2014 5:50 pm
The inner lip of the rear 1/3 of the front flares as a minimum, you'll probably get away without having to trim the rear.
PM Brindog, he used to run 215 and swap to 235 when heading bush.
Vehicle: jimny
Post Posted: Mon May 19, 2014 8:37 pm
i only just replaced the old HT 215/75-15s with rto3 hankooks, those HT's took me everywhere with careful wheel placement and the magic button
Vehicle: jimny
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 2832_n.jpg
click for an image of the updated tyre fitment
Vehicle: jimny
Post Posted: Wed May 21, 2014 8:49 pm
What is the difference in rolling diametre between 215 75 15, 235 75 15 & 30x9.5 and
Vehicle: Which one?
Post Posted: Thu May 22, 2014 6:54 am
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx
Although bear in mind that not all tyres are accurate in their sizing anyway, but that's a good guide.
Users browsing this forum: No registered users and 664 guests
