[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Tue Sep 01, 2009 11:08 pm |
I am in the process of installing my 6.5 gears. I have put the low and high speed gears onto the shaft, however there is a slight bit of play with the low speed gear. It moves side to side (not twisting) by less than half a mm, and the high speed gear is a tad less - Is this OK?
Mecho at work reckons it is OK, but I wanna check with techsperts.
Taff
Joined: Sun Aug 13, 2006 11:30 pm Posts: 889 Location: Brisbane
 Posted: Wed Sep 02, 2009 1:11 am |
I recently removed Rockhopper S3 gears that had been in for 3.5 years and they had a bit of play, replaced with trailmaster 6.5 and same amount of play.
I figured it was normal. You could probably shim between the spacer ring and the gear if you were a bit worried.
Also the 6.5s have done one trip now, very quiet at highway speeds. Only whine a bit at 40-50km/h.
11_evl
Joined: Tue Apr 10, 2007 11:30 pm Posts: 846 Location: logan reserve, Brisb
 Posted: Wed Sep 02, 2009 11:37 am |
Taff wrote: I recently removed Rockhopper S3 gears that had been in for 3.5 years and they had a bit of play, replaced with trailmaster 6.5 and same amount of play.
selling or sold rockhopper ones??
_________________ 92 sierra, 40" treps, full hydro, F&R steer, 106"W
Taff
 Posted: Wed Sep 02, 2009 7:28 pm |
Exploded them
TASSIETOYUKI
Joined: Mon Oct 27, 2008 10:30 pm Posts: 490 Location: Rosevears Tas
 Posted: Wed Sep 02, 2009 8:16 pm |
Taff wrote: Exploded them
Are you sure there is a problem with them... All of the "Rockhopper" gears i have seen looked like that
brendan
Joined: Sun Jul 27, 2008 11:30 pm Posts: 1484 Location: Sydney
 Posted: Wed Sep 02, 2009 8:43 pm |
fucken awesome!
_________________ navara on 33s. hopfully rear air locker soon
Rockhopper
Joined: Sun Jun 22, 2008 11:30 pm Posts: 1265 Location: Chipping Norton
 Posted: Thu Sep 03, 2009 1:16 am |
I had a slight amount of play in mine when I rebuilt the transfer, but it's been fine. Not really any noisier on the road, sounds a bit whinier than a standard transfer case when I'm crawling, but nothing too bad. I just figured it was pretty normal considering the size of the gears.
_________________ We're riding in the Ninky Nonk!
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 159 guests
