It is currently Wed Oct 28, 2026 8:49 am
Vehicle: '94 suzuki maruti
Post Posted: Sun Jan 11, 2015 6:45 pm
my brake drums are rubbing HARD on my backing plate. see attached picture, where shiny outer part wasnt previously shiny. the diff centres rebuilt, new HD axles with new bearings, what would cause this? its as though the axle is sitting too far in, or the backing plate too far out, but its not happening on the other side
Vehicle: Drover pickup turk
Post Posted: Sun Jan 11, 2015 7:02 pm
There's a little spacer that goes on the axle before the bearing, The gold coloured bit. My guess is this has been forgotten.
I like the tuna here
Post Posted: Sun Jan 11, 2015 7:18 pm
shit. had a mate do it. guess i'll get new bearings and give him a call haha! off memory there was nothing in there other than bearing. cheers.
aggravating because i've just put a gti motor in at the same time and cant test it out >.<
Post Posted: Sun Jan 11, 2015 7:27 pm
If you have NT axles then spacer is required.
If you have WT axles the spacer is built into the bearing.
Your problem is a missing spacer OR a bearing fitted backwards.
Post Posted: Sun Jan 11, 2015 9:38 pm
forgot key info :oops: wide track maruti. this was the kit purchased:
http://www.ebay.com.au/itm/Wheel-Bearin ... 35c7bae024
the things in the middle, top row were left out im pretty sure. meant to be fitted or no?
Post Posted: Sun Jan 11, 2015 9:54 pm
Yep that's them.
Users browsing this forum: Google [Bot] and 295 guests
