It is currently Sat Oct 24, 2026 11:49 pm
Vehicle: Jimny 2013 xroc2 40mmlift
Post Posted: Mon Mar 30, 2015 4:05 pm
Hi Everyone , I want to fit a snorkel -Safari dont make as of yet , would a 2011 Safari fit ? With minor interface mods to face of snorkel and guard ?
Dave .E
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Mar 31, 2015 8:13 am
not really, but you could just make one yourself from stainless. or go on jimnybits and get a short snorkel
Vehicle: 2014 Jimny Sierra
Post Posted: Wed Apr 01, 2015 12:01 pm
Hi Dave,
Yes you can I've recently found out. I just had one installed by Piranha on my 2014 Jimny last week (March 2015). Under the bonnet everything fits just fine, all that had to be done externally was to have a small angle bracket made up that is attached to the snorkel / car body where the snorkel comes up the side of the windscreen. I can take a picture of mine if you need it.
Unfortunately there's not too many other options for accessories for the post 2011 Jimny's short of custom fabricating something.
Andrew
Post Posted: Wed Apr 01, 2015 12:07 pm
Hi Andrew , great thanks for that , I was just about to get the safari and modify to fit but a pic would be great
Best Regards and thanx again
Dave.E
Post Posted: Wed Apr 01, 2015 12:34 pm
Dave.E
No worries, here's some pics. So the bracket is just 3mm aluminium. The only thing I've noticed is I get a little vibration when I initially accelerate hard (as in pedal to the floor) as its sucking harder. I might try putting a piece of foam / rubber underneath the bracket where it contacts with the body, otherwise maybe consider a steel bracket, might be a bit sturdier.
http://imgur.com/a/gyEb4
Very happy with it overall anyway. I can notice a slight power boost as well, particularly when accelerating up-hill. Next, i'm just try to decide on a bull bar...options are limited.
Post Posted: Wed Apr 01, 2015 12:51 pm
Thanks Andrew , just ordered the SS820HF snorkel , now looking at the Hi clone , that improved power and economy on my disco aswell , next is the exhaust to have more efficient flow without excessive noise . I have the $269 capped service schedule , on the reciept 2ltr suzi eng lube oil at $30 per litre, I should have got gold paint instead of silver lol wow!! .thanks again .cheers Dave .E
Post Posted: Wed Apr 01, 2015 1:30 pm
I'll have to look into the Hiclone myself, didn't know about those.
Post Posted: Wed Apr 01, 2015 1:40 pm
Its placed after the air flow/air temp sensor , it induces cyclonic spiralling of the intake air in the cylinder chamber creating a more efficient air /fuel Atomization and blending , better burn of fuel thus better energy conversion to the pistons downward power stroke . :)
Post Posted: Wed Apr 01, 2015 1:42 pm
Had them in my XY ,XF and disco's 2.4 diesel and 4.6 V8 Petrols .
Post Posted: Wed Apr 01, 2015 1:49 pm
Hi clones are about $ 175 ea , so justification for the expediture has to be done for the power/ economy obtained, but also, more IN means that the exhaust system needs adjustment for more out so larger dia exh piping/muffler is needed . Lol . but step by step, bank balance to bank balance easy as it goes Laddy :)
Post Posted: Wed Apr 01, 2015 5:53 pm
Andrew , try moving the intake scoop left or right , or . it maybe the distance(gap) between upper snorkel shaft and the windscreen/door frame frame , try the intake 1st , then try a towel between upper snorkel and windscreen .Dave
Post Posted: Thu Apr 02, 2015 11:50 am
I have tried removing the head completely (due to accidentally splitting it in half last weekend trying to squeeze through too-small-a gap lol). Was still getting the vibration on hard acceleration. Will definitely try the towel trick though see if that dampens it first before doing a permanent solution. Thanks.
Users browsing this forum: Google [Bot] and 207 guests
