It is currently Sun Jul 12, 2026 3:09 pm
Vehicle: lj50 soft top76
Post Posted: Tue Aug 25, 2015 9:08 pm
hi all, I am chasing the 3 small banjo bolts that hold the 3 oil feed lines onto the side of the crank case, (not the larger ones at the top on the cylinder block) or any ideas to where I can source them along with the rubber inserted flat washers, I tried copper washers and had air bubbles then over tightened the bolt n snapped it....... any help would be great thx
Post Posted: Wed Aug 26, 2015 2:17 pm
I have some second hand I could post you
Vehicle: LJ50V 2 stroke
Post Posted: Wed Aug 26, 2015 5:22 pm
i think there is a solution for the washers, from memory you can use ones from a Suzuki outboard with oil injection (can't remember the model though)
this is the only source for the washers with the rubber seal in the middle like original, that i know of. i'm happy to be proved wrong though ;)
Post Posted: Thu Aug 27, 2015 3:47 pm
thx for your help, I will check with our local Suzuki dealer thx, tanshi I will pm you thx
Post Posted: Wed Sep 09, 2015 5:31 pm
bump, need these to get a note out of my rebuild thx. anyone
bump, need these to get a note out of my rebuild. thx anyone!!!!!
Post Posted: Fri Sep 11, 2015 8:27 pm
I have them just missing one washer. I may be able to find one more washer to complete the set.
Let me know if you still need these?
Thanks Jamie
Post Posted: Fri Sep 11, 2015 10:36 pm
jamiec, you have a pm, thx
Post Posted: Tue Sep 22, 2015 5:50 pm
big thx to jamiec for helping me out with these bolts
