It is currently Wed Oct 21, 2026 9:09 pm
Vehicle: 85 Holden Drover
Post Posted: Wed Feb 03, 2016 4:47 pm
Hi all, just bought a drover on the weekend (Not really sure if i can ask about drovers on here but all well), and ive gone over it and found a few things that i want to fix. Im just after some info on how to fix the issues being the following (Keep in mind this is my first car so excuse the noobness):
-Rubber seal is coming out of the ball thing on the axle that goes into the wheel.
-Motor seems to be running rich and im using a fair bit of petrol.
-Some times after starting the motor i hear a high pitch scream sort of noise??
-Theres a little lever next to the throttle that when you push it, it revs the motor even more, however its not connected to the throttle it look like the link that connects it is broken??
- Sometimes when steering i hear a grinding noise??
Thanks in advance for the help.
Vehicle: 98 Jimny
Post Posted: Wed Feb 03, 2016 5:30 pm
I can only help on the high pitch squeel, that is the fan/alternator belt squeezing due to it getting wet or not being adjusted correctly.
Which in turn means it spins on the pulley creating the squeel. Make sure there are no coolant leaks around there causing it, and make sure it's tensioned correctly. Inspect the belt for wear and replace if needed
Vehicle: Suzuki Jimny Sierra 2015
Post Posted: Wed Feb 03, 2016 7:13 pm
I have seen a few Drovers on here :) so all is good mate!
is the "grinding noise" when steering are you at full lock (steering wheel left or right as far as it will go)?
the little lever sounds like a choke and is used for starting old cold engines, modern cars have computers that do all this for us now :(
put the choke into the position that makes it rev harder when is a cold morning otherwise leave it in the other position :)
without looking it up I would guess it has a carby and needs the fuel to air screw adjusted till it runs a little leaner but this is a trial and error type thing you will have to look into doing (try youtube) or get a mate who knows more/mechanic
if that suits you, but learning how to do these things your self will save money and give you a bit of pride :)
Post Posted: Wed Feb 03, 2016 8:55 pm
Cheers guys, and yes the grinding noise is more at full lock
Post Posted: Thu Feb 04, 2016 7:00 pm
grinding noise is the power steering, needs fixing, sorry my knowledge ends there but hopefully someone on here can help :)
Post Posted: Thu Feb 04, 2016 7:15 pm
It's unlikely to have power steering considering it would have to be retrofitted from a Vitara or jimny.
Post Posted: Fri Feb 05, 2016 8:05 pm
Ah lol yes! Any ideas what it might be?
Post Posted: Sat Feb 06, 2016 7:24 am
Right, in front of a computer for the first time in a while. Here's my thoughts.
Step one, Download a factory service manual for an SJ50. Don't attempt any job without it. Almost every bolt/fitting/item has a procedure and torque setting and the difference between long lasting job of factory quality and a patch up you need to revisit will be how closely to adhere to the FSM.
Buy and fit a steering knuckle rebuilt kit.
-Motor seems to be running rich and I'm using a fair bit of petrol.
(some/all) Drovers have a manual choke. it's likely to be that and has been rigged up in some random way over the years. using the FSM baseline the carby (put everything back to factory adjustment). It's likely the choke is partially on at all times and an owner has probably artificially lowered the idle speed to compensate.
Fanbelt is loose
Could be from a few places and isn't really indicative of a huge issue. could be tie rod ends, kingpins, steering box, steering shaft unis or steering column bushes. You might be able to find the source by spraying WD40 on/in the various steering components and see if it goes away.
Post Posted: Sun Feb 07, 2016 8:36 pm
Thanks so much mate
Users browsing this forum: No registered users and 331 guests
