It is currently Fri Jul 24, 2026 7:25 am
Post new topic Reply to topic  [ 131 posts ]  Go to page 1, 2, 3, 4, 5  Next
Vehicle: twin cam, twin locked, turbo
Post Posted: Thu Feb 11, 2016 5:15 pm
I just put a used centre in the rear of my swb wt today that has had an auto locker installed. The centre is being replaced by it's previous owner with bundera diffs.
I checked the backlash and it was within spec of the manual.
What sort of characteristics are normal for these style of lockers? I am hearing the clicking noise a lot more than I expected and it is louder than I expected, at very slight bends on a 90kph inner city bypass it was making the clicking noise (unlocking I assume) and unsettling the car with the slightest of bends. Should this be happening? It seems to have increased the drone from my tyres, is this normal?
Also what are the symptoms to indicate that the pins and spring require replacement?
Thanks
Vehicle: WT sierra, GU CRD
Post Posted: Thu Feb 11, 2016 6:31 pm
Sounds normal.
You will get a clicking as the locker "ratchets" around corners. If you want differential action, coast around corners.
If you want a spool, apply power around corners.
If you want a loud bang, turn tight with a bit of power :roll: :roll:
Edit: regarding your issue at 90km/h, if the thing unlocks around a corner it will unsettle the car. Either coast or drive through the corner.
I love ZD30. :)
Post Posted: Thu Feb 11, 2016 6:46 pm
Marko_SJ wrote:
Sounds normal.
Thanks. I had searched on the forum and found some answers but as this was a used locker I just wanted to confirm that it was normal, when I thought it should be clicking it sounded more like banging.
Post Posted: Thu Feb 11, 2016 7:49 pm
It should click as you turn corners, so long as you are coasting or have very light throttle.
If you accelerate on the normal spot you will get a bang unless it unlocks easily.
I love ZD30. :)
Post Posted: Thu Feb 11, 2016 8:15 pm
I have had trouble with 2 used auto lockers not holding their lock and constantly letting go when under load off road. I wont use used auto lockers again for this reason, but have had no problems with brand new ones.
Post Posted: Fri Feb 12, 2016 9:25 am
does COMPLETE SHIT count as a characteristic?
Post Posted: Fri Feb 12, 2016 11:20 am
YES
Funny, how you interpret what you read.
I had interpreted the research I had done as them being a bit to get used to on road and great off road, with a lot of indecipherable arguing.
I witnessed one off road and it appeared to be great.
Now reading the same posts after experiencing one I am reading completely different information.
I drive my car to and from work each day and on the 15klm home after fitting it I thought the whole diff was going to fall out.
I did only have 80/140 left to put in it last night and will change that to 80/90 today and see if that helps any.
Otherwise I might put a spool in my original centre and put it back in
Post Posted: Fri Feb 12, 2016 4:35 pm
Spools are predictable. And cheaper. And better.
Post Posted: Sat Feb 13, 2016 12:16 pm
What you described in the OP sounds like its too loose.
Too loose and too tight make for a bad time with an auto locker.
Ive have nothing but great experiences with Lockright lockers. The Spartan locker came out a few times for adjustment.
Post Posted: Sat Feb 13, 2016 12:43 pm
Thanks SierraDan. What requires adjustment?
I didn't fit the locker and my understanding is it has pre determined spacers to hold the outer collars at the correct gap.
Is this the area that needs to be adjusted? By reducing the length of the spacer to tighten or adding shims to loosen. I guess?
Is there a spec you have found to be optimum?
I set backlash of the ring gear to .13mm as the manual spec is .15-.10
Thanks
Post Posted: Sat Feb 13, 2016 12:59 pm
I would have auto lockers over a spool any time, if a spool was the only option then I would have nothing. Yes I have had both.
The only time I have had issues with a auto locker was when a small bit of plastic contaminated the locking surfaces.
Auto lockers also allow a wheel to turn faster then the crown wheel, that is the unlocking. Coasting has nothing to do with
how they work. Clicking is the sound of the outside wheel turning faster then the crown wheel.
Post Posted: Sat Feb 13, 2016 1:01 pm
Set back lash as per suzuki FSM and shim the side gears to spec of the locker manufacture.
The shims can wear causing a Locker to be loose.
The first step would be to work out which locker it is. There are at least 3 different auto lockers that fit wt rear diffs
Post Posted: Sun Feb 14, 2016 2:48 pm
Previous owner says it is lock right.
Gave it a good go off road and it is def an improvement.
On road it is awful. I never hear the expected ratcheting sound just random loud single clicks followed by vehicle direction change.
I will remove it in the next week or two and see if it is indeed a set up/ adjustment issue
Post Posted: Sun Feb 14, 2016 3:02 pm
It will need shimming, pins replaced or has debris preventing it from locking.
Either way it will need to be pulled out and inspected.
There are 2 different lockrites for sierra diffs so have to pull it out to see which one you have
Post Posted: Mon Feb 15, 2016 10:53 am
If it is popping out under power I would agree.
I only did about 10,000km with the locker in. It wasn't the best it could be but it wasn't unlivable either. Mine was a Spartan, should have went a lockrite I think.
As for coasting not making a difference, torque applied = locked, no torque (coasting) will allow it to ratchet.
I love ZD30. :)
Post Posted: Mon Feb 15, 2016 7:41 pm
My Lockrights were near silent.
Vehicle: Suzuki Jimny Sierra 2015
Post Posted: Mon Feb 15, 2016 7:44 pm
Front and rear Dan?
Post Posted: Wed Feb 17, 2016 10:29 am
Yeah mate.
Vehicle: WR250F/Jeep XJ
Post Posted: Wed Feb 17, 2016 12:37 pm
I never had a problem with my rear lockrite on 34" swampers. Sounds like a setup issue.
Post Posted: Fri Feb 19, 2016 6:42 pm
Pulled the diff out today.
Everything spec'd up as it should.
the thrust washers mic'd up at 1.05mm and the gap between the spacers and the pin was at the top end of the specs for the locker.
Shimmed it so that each thrust was 1.2mm
This has made a great improvement. Still not how I expect it to perform but a lot closer.
I will pull it out again when it annoys me enough :roll: and add another .02 of shims.
Post Posted: Sat Feb 20, 2016 7:57 am
If you have uneven tyre wear, for example 60% on one side and 85% on the other i have found this to contribute to the lock/unlock characteristics onroad
Post Posted: Sat Feb 20, 2016 8:05 am
Dissimilar tyre pressures can cause issues too.
Post Posted: Sat Feb 20, 2016 2:43 pm
Tyres are as close to identical as if they were new. Tyre pressures are checked frequently.
Vehicle: 98 Jimny
Post Posted: Sun Feb 21, 2016 11:04 am
Cap lockers are better.
Fixed it for you.
Post Posted: Sat Mar 19, 2016 2:12 pm
OK. I have pulled the diff again and shimmed the locker so as the pinion pin needed to be tapped in.
It was a huge improvement, no more random unlocking at speed.
However the ratcheting (or more correctly banging) noise in slow speed turns is unbearable.
Going to do away with this bloody thing.
Does anyone know a local supplier of spools?
Post Posted: Sat Mar 19, 2016 3:34 pm
Fixed it for you.
How did i miss this?
I know the exchange rate sucks atm, but grab a yukon off Low Range Offroad. I had mine in 4 days from being sent. Otherwise some do pop up for sale occasionally second hand.
Vehicle: 2000 Jimny
Post Posted: Mon Mar 21, 2016 9:48 am
had a spartan in the rear of my jimny for 6 days, great off road, total nightmare as a daily driven car. maccas drive thru was full of lols as i clicked & bounced around it. was also destroying my tyres.
saved & bought an air locker after that.
Vehicle: 86 GTI powered drover,96 coily
Post Posted: Fri Mar 25, 2016 12:32 pm
if you sell it give me a yell :D sounds like its exactly what i want.
guess your probably sick of it by now anyway but i found that in the nissans the mechanical lsd'd (which i assume are very similar to the lockers) the type of oil made a massive difference in the bangs (in several different brands of centers, nismo, cusco, i forget the other brand ive worked on). i forget which brand of oil it was now but i know it when i see the bottle, will try and remember to go have a look.
Post Posted: Fri Mar 25, 2016 1:24 pm
The Nissan mechanical LSD is nothing like an auto locker.
Post Posted: Fri Mar 25, 2016 6:05 pm
how so?
Users browsing this forum: Google [Bot] and 69 guests
