It is currently Sun Jun 07, 2026 5:59 am
Vehicle: Turboed 96 Softtop Vitara
Post Posted: Thu Aug 04, 2016 11:24 pm
Hi guys,
I have a buggared RH driveshaft on my 96 vitara. The front diff is a bitza. Steel main housing, ally centre/3rd arm housing. 5.12 gears and 26 spline side gears. (don't know is full diff centre change or side gear changed. (no locker)
Im struggling trying to find a replacement full shaft (spline to spline) for a vitara with a 26 spline inner shaft.
Will the RH drive shaft form a GV vitara fit?
besides the 22 vs 26 inner spline is there other differences with the vitara vs GV shafts?
Vehicle: JB420, APK416, A6G415, A6N415
Post Posted: Fri Aug 05, 2016 12:14 am
As far as I know the GV shafts are longer, and the inner CV splined stub is also longer.
Post Posted: Fri Aug 05, 2016 2:38 pm
Cheers.
I have a new 22 spline shaft.
Can I just pop the inner CVs and put the 26 spline CV on the new shaft?
Vehicle: 92 WT Sierra
Post Posted: Sat Aug 06, 2016 9:07 am
Gone.west I've tried that and the bearing cages at least in mine wouldn't swap over and a few other things stopped it. It's been awhile since I tried so can't remember what else there was.
Vehicle: 94 Vitara LWB
Post Posted: Sat Aug 20, 2016 10:24 pm
If its just the outter side thats broke just swap the end over, that is if its just the cage thats broken.
