It is currently Wed Oct 21, 2026 10:34 am
Vehicle: Suzuki Vitara 1992
Post Posted: Sat Oct 01, 2016 9:18 pm
So i have LWB vitara 2" coils, over the weekend i decided to see if they would fit.
Unfortunately the spring does not line up with the holes, i was thinking about cutting it to make it line up.
Anyone done this before? or sell them and get SWB coils?
This is 92 LWB to a 94 SWB vitara coil springs.
Post Posted: Sat Oct 01, 2016 9:42 pm
150% SWB and LWB Vitara springs are interchangeable. The spring seats are exactly the same between the two models.
Promise. I've swapped springs between SWB and LWB Vitaras frequently. I run LWB vitara rear spring seats and hats in the front of my sierra and I swap between LWB rear, SWB rear, and Tough Dog SWB rear all the time. Likewise at the front, any vitara can take SWB, LWB, 2.0 and V6 springs and early GV springs. I have swapped them all (although the GV springs give excessive lift and rate)
Don't cut the springs.
Post Posted: Sat Oct 01, 2016 9:49 pm
Im all new to this stuff but i try and give everything a crack, So where the spring sits in the top (rubber) that can be moved around?(spin) If so it will fit...i didnt even think to see if i could move it.
Post Posted: Sat Oct 01, 2016 9:59 pm
Yes - the rubber can be removed & rotated, but, really, why bother? Position the spring so the tail sits in the correct place on the control arm and you'll be fine.
Post Posted: Sat Oct 01, 2016 10:06 pm
Yeah but it lifted it much bigger then 2" this is it after install the Coil. http://imgur.com/a/LhcM1 Thats with one not in the slot.
Post Posted: Sat Oct 01, 2016 10:08 pm
You have something very wrong. Are you sure you haven't tried to install rear springs in the front? can you post a picture of the spring in place?
Post Posted: Sat Oct 01, 2016 10:18 pm
I didnt grab a picture of the springs in place, yeah i think its the front, Here is a picture of the coils...i install the fat one in the front....was in the front on my LWB.
http://imgur.com/a/MC1j8
Post Posted: Sat Oct 01, 2016 10:31 pm
OK, in any case, you have a significant problem with fitment. don't drive the car like that, especially in 4WD - it will cause havoc with the CV's and RH axle.
You need to get those springs seated properly.
Post Posted: Sat Oct 01, 2016 11:53 pm
Only fitted it to one side to see how it was, it wasn't seated properly at all, which may have caused it to sit higher.
Users browsing this forum: Google [Bot] and 153 guests
