It is currently Sun Jun 07, 2026 12:02 am
Vehicle: 2" 97 Coily on 30's
Post Posted: Mon Jan 09, 2017 9:15 pm
Just wondering if a coily gearbox is any different to a "normal" 1.3 one?
Will I have any problems putting a "normal" one in my coily ?
Thanks in advance.
Post Posted: Mon Jan 09, 2017 9:17 pm
AFAIK coily ones are the same. The only difference i can see externally is the coily doesnt have the hole for timing on the bellhousing.
Post Posted: Tue Jan 10, 2017 5:53 am
So how do you time the motor if you have an non-coil g13?
Gear ratio is also different in 5th
Post Posted: Tue Jan 10, 2017 9:00 am
I thought the difference in 5th was NT to WT era Steve?
Post Posted: Tue Jan 10, 2017 9:40 am
Not as far as I am aware. Coil was shorter due to the taller transfer ratios. I recall this from when the coil Sierras was released. As always, could be wrong though.
Users browsing this forum: No registered users and 3 guests
