It is currently Sun Jun 07, 2026 5:17 am
Vehicle: 1988 US Samurai
Post Posted: Mon Mar 20, 2017 5:34 am
Did the g13bb in Jimny come with a crank position sensor? I ask because all of the g13bb motors in United States had one, but our version of the Jimny got the axe in 1996. When i look at G13bb oil pans on AU ebay they don't have a hole for the crank position sensor.
Post Posted: Mon Mar 20, 2017 6:52 am
G13bb's don't have the crank position sensor.
If you need a rwd pan with a crank position sensor I believe late x-90's and GV 1.6's work. I have seen a late efi vitara (circa 1997 or thereabouts) with a crank sensor sump but no sensor installed. Otherwise it's a cut and shut job
Post Posted: Mon Mar 20, 2017 8:17 am
Check megazip.
They should list a sump with ckp sensor hole.
I would look, but not at a pc atm.
Post Posted: Mon Mar 20, 2017 10:46 am
I think some spain built convertables run g13bb with crank sensors
Post Posted: Mon Mar 20, 2017 12:48 pm
The 1.6 pans fit. But when i bolted it up it had clearance issues with the front axles. My Samurai is almost stock height, just a set of OME springs.
Do your g13bb have a distributor? It doesn't seem like the cam position sensor alone would have enough resolution to do coil packs, even wasted spark.
Post Posted: Mon Mar 20, 2017 12:53 pm
jdk81 wrote:
Check megazip.
I've never seen megazip before. is it pretty reputable?
Post Posted: Mon Mar 20, 2017 1:06 pm
bb has a camshaft position sensor.
Coil pack balenos have both cam and crank.
Sounds like you're going to need to cut and shut a pan.
Post Posted: Tue Mar 21, 2017 1:28 am
Maybe I'm a bit slow, but you're saying that g13bb have a cam position sensor, no crank, and coil packs?
I have a modified pan. I've had it off twice now due to leaks, but I think I have it on leak free this time....
Post Posted: Tue Mar 21, 2017 5:50 am
Correct. Although as has been pointed out it seems that some (all?) convertible jimny's, which were made by Santana in Spain, are g13bb's with both.
Convertibles are rare here however.
