Vehicle: 96 Coily Tin Top
Posted: Mon May 08, 2017 8:19 pm
Hey guys,
I've got a case of the needle wobbles in my coily. Have just replaced the old speedo cable with a new one however its still wobbling about below 40kms. I should have split the cluster when i had it out but i thought the new cable would have done the trick. I was wonder if anyone had any guidance on inspecting the speedometer components within the cluster. Thought that the speedo head might be worn out but am unsure whether replacements parts can be sourced new or if its a case of finding second hand bits.
Posted: Tue May 09, 2017 8:49 am
Cheers for the heads up Alien, I've striped the cluster down and removed the speedo gauge which seemed to have a bit of a rattle when you move it side to side so my guess is that something inside it has possibly let go. Its still reading the speed correctly as far as im aware as ive checked it against gps, however it has been rattling for about 2 weeks which is getting pretty old lol.
Users browsing this forum: No registered users and 238 guests
