Joined: Wed Sep 21, 2011 11:04 am Posts: 73 Location: Mooroolbark Victoria
Posted: Sun Jun 03, 2018 8:54 pm
MCTUFF is for sale. At least the Sierra formerly reg as McTuff is. This is a much modified 85 N /T Starting at the front :- Steel bull bar with warn winch. New unused dyneema rope and hook. Pair Narva driving lights. GTI twin cam engine. Not currently running, needs new rotor button or dizzy cap. I have not changed it because the cap is against the firewall so motor needs to be partly removed or pulled forward to allow removal. everything else has been tested as ok. has noisy thrust bearing in clutch. Modified Gti big bore exhaust. The transfer case has been lifted 25mm and fitted with Calmini 5.14 low range gears and modified mounts. has Twisted 'T' transfer shifter. standard 3.9 diffs with front and rear lockright auto lockers. New EFS springs all round with 60-65mm lift. new gas shocks. 31 x 10.5 Maxxis Bighorns on 8" Sunraysia rims. Vitara power steering 4 wheel disc brakes - disc brake handbrake on transfer. GTI front seats Roll bar behind seats rear seat not fitted - false floor for storage under. Steel custom snorkel. I have had this car for 17 years It is not engineered with the mods but all steering brakes etc are Suzuki with engineered kits for fitting. The body is tidy but with some light damage on r/h/s. This is a great basis for a project build as you can imagine the cost to fit everything done. this car used to be dragged on a trailer behind my motor home so has only done 205000 kms. In 17 years it has only done approx 25,000 because it was never a daily driver $2,200 unreg and unroadworthy
Users browsing this forum: No registered users and 9 guests
