It is currently Fri Jul 24, 2026 10:40 am
Vehicle: Vitara
Post Posted: Sat Sep 12, 2020 10:16 am
Does anybody know who makes new ring and pinion gears to fit a Vitara, or where I can get them from. I can’t find any new ones for sale on line, and beakers yards here in Perth charge like wounded bulls for an old set, that’s as old as the one I want to replace.
Also has anybody had any experience using solid spacers between the pinion bearings? Would be keen to know what you used and how it worked out.
Post Posted: Sat Sep 12, 2020 10:40 am
Suzistore in midland got me a new rear 5.12 ring & pinon in for me from Japan $580, or if ya going bigger tyres zookoffroad sell gears too suit for about the same price but obviously you'll spend double the money for two diffs
Vehicle: Vitara
Post Posted: Sun Sep 13, 2020 8:33 am
Thanks Joe I’ll talk to them on Monday
Post Posted: Wed Sep 16, 2020 9:50 am
My understanding (jono165, who isn't on here often now can confirm) is a Hilux solid spacer kit works, but requires exactly 5.00mm machined off of it. These kits are available from Lowrange offroad (the 4 cylinder version is the applicable part AFAIK)
https://www.lowrangeoffroad.com/toyota- ... nd-v6.html
I had a workshop make a solid spacer for my Sierra many years ago, and I never had an issue with pinion seal failure or loss of preload in the years I ran it with 35's.
As for reusing gears- if they've come from a diff with good bearings/no pinion play and pass a visual inspection, there's no issue putting them into a rebuilt diff. It makes no sense to pay huge money for new ring and pinion gears with the same ratio as those commonly found locally. Most Vitaras have only been used lightly on road so gear wear isn't a significant issue. If they've been low on oil (about the only problem) you'll see pitting on the gear teeth.
Post Posted: Wed Sep 16, 2020 10:06 am
I've had shit luck with second hand diffs that's why I bought new gears
Vehicle: 2020 Vitara Turbo
Post Posted: Thu Sep 17, 2020 6:35 am
There's a local wrecker in Bunbury that seems to get a bunch of good Vitaras. We stripped 4 diffs and all where in great condition.
Vehicle: Vitara
Post Posted: Mon Sep 21, 2020 9:06 pm
Thanks for all the advice. After trying to find a reasonable priced ring gear and pinion I bit the bullet and ordered one from Japan. Thanks for link to the Toyota spacer upgrade, I do like the idea of using a solid spacer.
Post Posted: Thu Sep 24, 2020 2:49 pm
I still check in here occasionally - low range has made it easier since I did a solid spacer on my sierra.
They now make a solid spacer that is already the correct length for a suzuki diff.
https://www.lowrangeoffroad.com/suzuki- ... x-sps.html
Vehicle: Vitara
Post Posted: Sun Sep 27, 2020 11:37 pm
Yeah I ordered two solid spacers from low range earlier this week. I'll let you ok now how they work out
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 329 guests
