It is currently Fri Jul 24, 2026 10:49 pm
Post Posted: Wed Oct 07, 2009 2:20 am
hey guys just wondering how do i remove the metal bracket behind ya kick panel plastic
should i just drill the spot welds out?
the reason i want 2 remove this is cause im making up some custom sliders
like these
Vehicle: Currently vehicle-less
Post Posted: Wed Oct 07, 2009 2:40 am
get a grinder, and just grind them down finely - they are only spot rivet type things. Once you get the bracket ground down far enough, they should just pop off easy. Then sand the heads back.
Thats how I did mine anyways and it was really neat and pretty simple, just take your time.
Post Posted: Wed Oct 07, 2009 3:10 am
Use a 1mm grinding disc. easier for fine work
Post Posted: Wed Oct 07, 2009 3:32 am
ahh yea should have specified that, sorry!
Post Posted: Wed Oct 07, 2009 4:02 am
spot weld drill bit
Post Posted: Wed Oct 07, 2009 7:00 am
grinder and flappa disc.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Vehicle: 1999 Jimny
Post Posted: Wed Oct 07, 2009 10:56 am
http://cgi.ebay.com.au/H-S-S-3-8-10mm-R ... 911.c0.m14
these are brilliant
Post Posted: Wed Oct 07, 2009 11:36 am
The spot weld bit works good, but if you are a bit rough like me you might end up with a 10mm hole in your sill :lol:
Post Posted: Wed Oct 07, 2009 2:50 pm
This is what I used. Quick and easy with no holes left when you're done. I used a thicker disc though, 3-4mm? thick. It was easier to use a big blunt edge than a fine edge. Just go really slowly so you don't end up grinding the sill as well.
Post Posted: Wed Oct 07, 2009 3:01 pm
i just drilled them out, when i stuck the cheaker plate on just make sure there sikaflex on the holes
navara on 33s. hopfully rear air locker soon
Post Posted: Wed Oct 07, 2009 9:04 pm
cheers 4 all the input guys
Post Posted: Wed Oct 07, 2009 9:41 pm
ive just taken the drivers side off and not even any surface rust i ended up using my dremal with a grinding disk on it worked a treat will little marking underneather
so thats 1 down now i got 2 get my ass round 2 getting the other 1 off lmfao
Users browsing this forum: No registered users and 654 guests
