Joined: Sat Oct 16, 2010 2:02 am Posts: 96 Location: Wellington NZ
Posted: Mon Aug 04, 2025 8:44 am
Hello Team, I have a 1992 SWB vitara. The Tacho is not working, and I am considering an after market tachometer. Where is the pulse pick up located on this model? ECU or coil? Pete
I assume you have a TBI 8v model, Australia didn’t receive that model so local experience will be patchy. I suspect it will be off the coil as per the carb version.
I’d determine why the stock tach isn’t working- it might be a simple fix.
Posted: Mon Aug 04, 2025 1:10 pm
Hello Steve,
It is a 16v injected model. I have swapped out the tacho head foe another, but no go. I thought I may be able to check if there is in fact a pulse from the source also. Some info says it originates from the the radio suppressor at the coil. Not sure what that looks like though.
Users browsing this forum: No registered users and 325 guests
