It is currently Tue Oct 27, 2026 5:08 pm
Post Posted: Wed Jun 02, 2010 5:34 am
sorry couldn't find a thread
my mate rolled his vitara so i grabed some stuff of it :D , including a 60 ltr fuel tank to replace my dented 40ltr
has any one already dun this and if so could you put up some pics thanks
the dent takes up pretty much 6ltr's so im pretty desperate :?
Post Posted: Wed Jun 02, 2010 6:48 am
Id say, don't do it, under any means, it is fraught with danger, serious danger. Send it to me to have a look.
Vehicle: lj81 stockman
Post Posted: Wed Jun 02, 2010 7:22 am
i have an 80l and it hits lots of things
the wobble rocks
Post Posted: Wed Jun 02, 2010 7:32 am
Taff fitted a SWB Vitara tank to his Sierra... Check his thread in RIGS.
Post Posted: Wed Jun 02, 2010 9:02 am
thats in a long wheel base isnt it tho??dont know if there is any difference.A mate has one in his custom lwb
PJZOOK i believe has one in a shorty
Post Posted: Wed Jun 02, 2010 9:08 am
Same spot & mount's, as long as it's not a factory ute..
Post Posted: Wed Jun 02, 2010 9:13 am
What model is it from?
The LWB tanks (55L) are quite wide, and, from memory, won't sit between the chassis rails.
There's a tall wide tank (2.0 SWB EFI?) that would be a PITA to fit.
The 70-75 litre GV tank won't fit anywhere without bashing it into shape. It's huge. It's not going in a SWB.
THe 1.6 SWB EFI tank is a nice fit but it's only 45L. It is a fair fabrication job to make it fit as all the mounts have to move. It's easier with a 2" BL too.
Post Posted: Wed Jun 02, 2010 9:15 am
LOL nice =)
Post Posted: Wed Jun 02, 2010 9:24 am
that's what I put in Buttercup, lot's of work, I don't think I kept 1 original mount..
As for body lift, You can make it fit with out it.
Post Posted: Wed Jun 02, 2010 9:28 am
I'm sure you can. They sit nice and high with a BL though.
Post Posted: Wed Jun 02, 2010 9:32 am
Yer, that look's about 20 000 000 000 time's better than what I did, no were near as high as that, make's me want to go & do mine again.
Post Posted: Wed Jun 02, 2010 9:38 am
I don't have any meaningful photo's, but I did another one that we raised the floor of the car 2", along with the 2" BL. The bottom of the tank flange is level with the crossmember. The tank isn't much lower than the chassis rail.
Post Posted: Wed Jun 02, 2010 10:00 am
Raising the floor was running through my mind, but that was it.
I am planing to run a steel guard, but i see ho much departure I could gain judging by that pic.
Still not a fan of BL tho.
I do see the advantage's but don't like it.
Post Posted: Wed Jun 02, 2010 10:15 am
BLless cars are cool, but most people aren't willing to cut that far to run the tyre sizes we run at the lift heights we want to run them
No BL, 35's:
You'll notice the front flares overlap the bonnet. A lot. :D
PS this car runs a vit tank with the flange bolted to the floor behind the front seats. The filler is just behind the passenger side B pillar. No clearance problems there :wink:
Post Posted: Wed Jun 02, 2010 10:29 am
now that is cool steve.alot of chopping involved there 8) but all for good reason,getting bigger tank up,great angles,big clearance.
id body lift before hacking that much tho but good on yas for making it work.Hate hard tops without doors on,make him some half doors :wink:
Post Posted: Wed Jun 02, 2010 11:09 am
I agree about the 1/2 doors... but the owner doesn't dig them.
He took the GF on her first trip on the W.E - No doors. It was 6? when we aired down.
Word.
PS that car makes a mockery of all the work I've put into cars over the years. carby 1.6, trimatic, 4:1 case, 3.9 diffs, spool/detroit RUF, Vit PS. OME springs, some ranchos the owner had lying around. 15X8 KMC beadlocks and 35" Krawlers. It's owned everything it's driven to date. It's awesome - and it was a 6 week build- and with 31's on it, it's his DD and you wouldn't look at it twice on the road because it's almost stock height.
Post Posted: Wed Jun 02, 2010 11:40 am
cool cool.sorry to drag this thread off topic but how do you guys find power steer with the bigger tyres???33,34,35s etc?Do they get hot,have yas plumbed a little cooler in ret?
Post Posted: Wed Jun 02, 2010 11:50 am
We use falcon pumps and apart from the belts slipping the steering is fine.
Post Posted: Wed Jun 02, 2010 12:20 pm
I put the 55L vit fuel tank in mine.
I have 2" BL, and removed the breather bottle and used the stock on.
I had to use washers to shim it, so there wasnt any rubbing etc going on.
The biggest pain was actually the exhaust. It required some heat shielding and a new rear section from the mufler.
The front bolt holts on the tank are directly below the chasis rail which supports the shock absorbers on the rear, and the brackets fit inside nicely.
The rear bolts up in line with the tube x member on the rear. It was easier for me to put the angle iron all the way accross.
I still need to replace the shims with a flat strap, to spread the load better.
Vehicle: Zookless
Post Posted: Wed Jun 02, 2010 12:55 pm
Did this require cutting and welding of the shock cross-member?
Post Posted: Wed Jun 02, 2010 1:44 pm
http://www.auszookers.com/index.php?nam ... &start=150
Swb Vit efi tank. I measured it by water. 50L
2" BL, Bashed floor, Original expansion tank next to filler. Hose cut and shut with pipe to suit. Brackets for crossmember to original holes. Other mounts straight through chassis.
Post Posted: Wed Jun 02, 2010 3:08 pm
i think i can do it i cant remember the year and model of the vit but bye the looks of things the tank is a bit close to the chassis and the other side the exhaust.
i was thinking i would jus make a guardwile its off to cover the bottome.
nice wheels
thanks for the help ill need to run it by the old man before i do much
Post Posted: Wed Jun 02, 2010 8:52 pm
I did cut the stock fuel tank mounts off.
I use a 3mm plate which bolted up to the shock cross member) to spread the load, and welded some mounts which drop down from that to the tank.
Users browsing this forum: No registered users and 234 guests
