| Author |
Message |
atari4x4
 Posted: Tue Sep 15, 2009 8:52 pm |
Polar_Bear
Joined: Sat Aug 12, 2006 11:30 pm Posts: 2511 Location: Adelaide SA
 Posted: Wed Sep 16, 2009 12:08 am |
you bored at work? shouldnt you be photochopping?
_________________ Go Hard, Trailer Home
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Wed Sep 16, 2009 12:45 am |
That look`s good. stuff work, Suzuki`s are much more fun.
Hang on, Suzuki is my work!!!
_________________ I used to be indecisive,
atari4x4
 Posted: Wed Sep 16, 2009 12:50 am |
Polar_Bear wrote: you bored at work? shouldnt you be photochopping?
if only i could weld as good as i can photochop....
atari4x4
 Posted: Wed Sep 16, 2009 12:52 am |
steknig wrote: That look`s good. stuff work, Suzuki`s are much more fun. Hang on, Suzuki is my work!!!
 cheers, gotta thank Polar_Bear for the steel & hot glue gun!
Westie
Joined: Tue Jul 04, 2006 11:30 pm Posts: 1417 Location: Caloundra Sunshine
stem1
Joined: Tue Aug 20, 2013 10:03 am Posts: 53 Location: Cairns
Vehicle: '90 Vit, 16b, high and wobbly,
 Posted: Sun Oct 20, 2013 7:26 pm |
anybody making these? Thanks
christover1
Joined: Tue Jul 15, 2008 11:30 pm Posts: 8203 Location: Melbourne
 Posted: Tue Oct 22, 2013 4:02 pm |
If buying an idler arm brace off the internet, check if it suits right hand drive or not. I bought an upgraded idler arm/mount from Sky Manufacturing. That is another option.
atari4x4
 Posted: Tue Oct 22, 2013 4:04 pm |
bits4vit's have a listing for a idler arm brace, lowrangeoffroad have a listing for the replacement sky manufacturing idler arm.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Tue Oct 22, 2013 4:06 pm |
is there even much call for them? might be something simple to add to the stock list
atari4x4
 Posted: Tue Oct 22, 2013 4:11 pm |
yeah, the idler arm bracket is weak as piss & is in single shear... can be put under a lot of stress especially if the front end is locked, leaving you with wheels pointing at each other.
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Sun Oct 27, 2013 6:37 pm |
i bought one from low range over a yr ago because i was going a bigish order and thought "why not", got it fitted a few months back and its a lot nicer to drive with (smoother steering) and just another thing that wont break on the trail. well worth it.
H3DR4N
Vehicle: 1988 suzuki vitara
 Posted: Sun May 11, 2014 11:05 am |
Nice work will have to make something similar for my build thanks for the info
RJ6
Vehicle: 1991 Geo Tracker
 Posted: Thu Feb 25, 2016 1:02 am |
RJ6
 Posted: Thu Feb 25, 2016 12:14 pm |
atari4x4 wrote: The Vitara idler arm is a known weak point when running bigger tyres, and after checking out a few different designs I came up with this set-up. The front of the 2.0 Liter Vitara's are slightly different the the 1.6 Liter Vitaras.
<SNIP>
#1. Are the idler arms themselves different, or is it just the location?? #2. Would the following heavy-duty idler arm fit in a 2.0 Liter Vitara?? http://www.sky-manufacturing.com/cgi-bi ... E-HDIA-001
tanshi
 Posted: Thu Feb 25, 2016 12:38 pm |
firstly your looking at American sites. being that they drive on the other side of the road to us they probably wont fit
atari4x4
 Posted: Thu Feb 25, 2016 12:40 pm |
also 7 years ago there wasn't any support for the SV's
RJ6
 Posted: Thu Feb 25, 2016 4:53 pm |
atari4x4 wrote: bits4vit's have a listing for a idler arm brace, lowrangeoffroad have a listing for the replacement sky manufacturing idler arm.
shandy92 wrote: i bought one from low range over a yr ago because i was going a bigish order and thought "why not", got it fitted a few months back and its a lot nicer to drive with (smoother steering) and just another thing that wont break on the trail. well worth it.
Does anybody know whether or not "shandy92" had a 1.6 L Vitara or a 2.0 L Vitara??
atari4x4
 Posted: Thu Feb 25, 2016 5:01 pm |
RJ6 wrote: atari4x4 wrote: bits4vit's have a listing for a idler arm brace, lowrangeoffroad have a listing for the replacement sky manufacturing idler arm.
Does anybody know whether or not "shandy92" had a 1.6 L Vitara or a 2.0 L Vitara?? RJ6 wrote: atari4x4 wrote: bits4vit's have a listing for a idler arm brace, lowrangeoffroad have a listing for the replacement sky manufacturing idler arm.
RJ6
 Posted: Fri Feb 26, 2016 1:36 am |
shandy92
 Posted: Fri Feb 26, 2016 6:24 am |
RJ6 wrote: Does anybody know whether or not "shandy92" had a 1.6 L Vitara or a 2.0 L Vitara??
Hey, mine is a 1.6efi
christover1
 Posted: Fri Feb 26, 2016 6:36 am |
My Sky idler arm is still going strong. Steering smoothed up and got more precise when fitted. Has stayed that way.
RJ6
 Posted: Fri Feb 26, 2016 8:12 pm |
christover1 wrote: My Sky idler arm is still going strong. Steering smoothed up and got more precise when fitted. Has stayed that way. Have you ever heard of anybody who installed or tried to install the Sky Heavy Duty Idler Arm in a 2.0 Liter Vitara?
christover1
 Posted: Fri Feb 26, 2016 8:22 pm |
Put a stock idler arm from each model together and take a look. I have no idea if they are the same, but they should be.
christover1
 Posted: Fri Feb 26, 2016 8:31 pm |
RJ6
 Posted: Fri Feb 26, 2016 9:28 pm |
christover1 wrote: "atari4X4", do the Steering-Idler-Arm-Assemblies in your 2.0 Liter SV420 and SV620 Vitaras look like the one in the picture above??
RJ6
 Posted: Fri Feb 26, 2016 11:05 pm |
#1. According to the following URL or link, the Steering-Idler-Arm-Assembly is the same for all Vitaras from 1988 to 1999: http://www.ebay.com.au/itm/Steering-Idl ... 0892927045#2. However, according to the following URL or link, the last Australian 1st Generation Vitara was made or sold in 1998: https://www.suzistore.com#3. Is that a contradiction or typographical error??
RJ6
 Posted: Sat Feb 27, 2016 2:56 am |
shandy92
 Posted: Sat Feb 27, 2016 11:05 am |
Mate, there is a good chance that it will fit, and a small chance it wont. If u buy it and it doesnt fit, sent it back or sell it locally.
fordem
 Posted: Sun Feb 28, 2016 10:35 am |
RJ6 - I just checked the Suzuki EPC - there was one idler arm part number used on ALL the SE & SV series Vitaras, regardless of engine size or steering wheel position.
