It is currently Mon Sep 07, 2026 11:58 am
Post new topic Reply to topic  [ 75 posts ]  Go to page 1, 2, 3  Next
Post Posted: Tue Sep 15, 2009 8:52 pm
The Vitara idler arm is a known weak point when running bigger tyres, after checking out a few different designs I came up with this set up. The front of the 2.0l vitara's are slightly different the the 1.6's.
I have been running this set up for a few years now & it's still going strong, thanks Polar_Bear for the steel & the welding. Armsup Armsup
cardboard template
steel cut
mocked up
i still need to drill that hole out to M8 & bolt it all up.
Here is Polar_Bears stock idler arm bracket after he bent it & his Idler arm brace that he made up for the 1.6l Vitara.
Post Posted: Wed Sep 16, 2009 12:08 am
you bored at work? shouldnt you be photochopping? :finger:
Go Hard, Trailer Home
Post Posted: Wed Sep 16, 2009 12:45 am
That look`s good. stuff work, Suzuki`s are much more fun.
Hang on, Suzuki is my work!!!
Post Posted: Wed Sep 16, 2009 12:50 am
if only i could weld as good as i can photochop.... :thefinger:
Post Posted: Wed Sep 16, 2009 12:52 am
8) cheers, gotta thank Polar_Bear for the steel & hot glue gun!
made one of these for the Trolly when I had it look here http://auszookers.com/index.php?name=Fo ... 4&start=75
Steve W
Vehicle: '90 Vit, 16b, high and wobbly,
Post Posted: Sun Oct 20, 2013 7:26 pm
anybody making these?
Thanks
Post Posted: Tue Oct 22, 2013 4:02 pm
If buying an idler arm brace off the internet, check if it suits right hand drive or not.
I bought an upgraded idler arm/mount from Sky Manufacturing.
That is another option.
Post Posted: Tue Oct 22, 2013 4:04 pm
bits4vit's have a listing for a idler arm brace, lowrangeoffroad have a listing for the replacement sky manufacturing idler arm.
Post Posted: Tue Oct 22, 2013 4:06 pm
is there even much call for them? might be something simple to add to the stock list
Post Posted: Tue Oct 22, 2013 4:11 pm
yeah, the idler arm bracket is weak as piss & is in single shear... can be put under a lot of stress especially if the front end is locked, leaving you with wheels pointing at each other.
Post Posted: Sun Oct 27, 2013 6:37 pm
i bought one from low range over a yr ago because i was going a bigish order and thought "why not", got it fitted a few months back and its a lot nicer to drive with (smoother steering) and just another thing that wont break on the trail. well worth it.
Vehicle: 1988 suzuki vitara
Post Posted: Sun May 11, 2014 11:05 am
Nice work will have to make something similar for my build thanks for the info :)
Vehicle: 1991 Geo Tracker
Post Posted: Thu Feb 25, 2016 1:02 am
#1. Low Range Off Road 1989-1998 Suzuki Sidekick, Geo Tracker, X90, Vitara, Escudo, Sunrunner Idler Arm Brace:
http://www.lowrangeoffroad.com/suzuki/s ... r-iab.html
#2. FTS Idler Arm Brace for 1st Generation Vitara 2.0 Liter Engine:
TEL: 886-4-2515-0099, FAX: 886-4-2529-1701, E-mail: fts.fts@msa.hinet.net
http://www.fts4x4.com/en/products/?meth ... il&aid=251
Post Posted: Thu Feb 25, 2016 12:14 pm
The Vitara idler arm is a known weak point when running bigger tyres, and after checking out a few different designs I came up with this set-up. The front of the 2.0 Liter Vitara's are slightly different the the 1.6 Liter Vitaras.
<SNIP>
#1. Are the idler arms themselves different, or is it just the location??
#2. Would the following heavy-duty idler arm fit in a 2.0 Liter Vitara??
http://www.sky-manufacturing.com/cgi-bi ... E-HDIA-001
Post Posted: Thu Feb 25, 2016 12:38 pm
firstly your looking at American sites. being that they drive on the other side of the road to us they probably wont fit
Post Posted: Thu Feb 25, 2016 12:40 pm
also 7 years ago there wasn't any support for the SV's
Post Posted: Thu Feb 25, 2016 4:53 pm
Does anybody know whether or not "shandy92" had a 1.6 L Vitara or a 2.0 L Vitara??
Post Posted: Thu Feb 25, 2016 5:01 pm
yess!!
Post Posted: Fri Feb 26, 2016 1:36 am
#1. Bits4Vits doesn't list idler arm braces anymore:
http://www.bits4vits.co.uk/store/index.php
#2. Mods4Vits & Jimnybits list them, but they don't include bolts with lock washers & Permatex thread locker like Low Range Off Road:
http://www.mods4vits.com/index.php?main ... ucts_id=22
http://www.jimnybits.co.uk/shop/vitara- ... _1490.html
http://www.lowrangeoffroad.com/suzuki-o ... r-iab.html
#3. Low Range Off Road doesn't sell the heavy duty idler arm from Sky anymore:
Post Posted: Fri Feb 26, 2016 6:24 am
Hey, mine is a 1.6efi
Post Posted: Fri Feb 26, 2016 6:36 am
My Sky idler arm is still going strong.
Steering smoothed up and got more precise when fitted.
Has stayed that way.
Post Posted: Fri Feb 26, 2016 8:12 pm
christover1 wrote:
My Sky idler arm is still going strong. Steering smoothed up and got more precise when fitted. Has stayed that way.
Have you ever heard of anybody who installed or tried to install the Sky Heavy Duty Idler Arm in a 2.0 Liter Vitara?
Post Posted: Fri Feb 26, 2016 8:22 pm
Put a stock idler arm from each model together and take a look. I have no idea if they are the same, but they should be.
Post Posted: Fri Feb 26, 2016 8:31 pm
http://www.ebay.com.au/itm/Steering-Idl ... 0892927045
Stocker is same according to this trusted seller
Post Posted: Fri Feb 26, 2016 9:28 pm
"atari4X4", do the Steering-Idler-Arm-Assemblies in your 2.0 Liter SV420 and SV620 Vitaras look like the one in the picture above??
Post Posted: Fri Feb 26, 2016 11:05 pm
#1. According to the following URL or link, the Steering-Idler-Arm-Assembly is the same for all Vitaras from 1988 to 1999:
#2. However, according to the following URL or link, the last Australian 1st Generation Vitara was made or sold in 1998:
https://www.suzistore.com
#3. Is that a contradiction or typographical error??
Post Posted: Sat Feb 27, 2016 2:56 am
The following sellers say 1989 to 1998 for a Vitara Idler Arm, but they don't mention the engine size:
http://www.ebay.com.au/itm/1-IDLER-ARM- ... DdBdH5RWdg
http://www.ebay.com.au/itm/1-X-IDLER-AR ... SwFqJWkLKS
Post Posted: Sat Feb 27, 2016 11:05 am
Mate, there is a good chance that it will fit, and a small chance it wont. If u buy it and it doesnt fit, sent it back or sell it locally.
Post Posted: Sun Feb 28, 2016 10:35 am
RJ6 - I just checked the Suzuki EPC - there was one idler arm part number used on ALL the SE & SV series Vitaras, regardless of engine size or steering wheel position.
Users browsing this forum: No registered users and 37 guests
