| Author |
Message |
harry loane
Joined: Mon Oct 01, 2012 7:11 pm Posts: 86 Location: wauchope
Vehicle: 1986 sj50 suzuki sierra
 Posted: Wed May 22, 2013 9:59 pm |
hey guys i just thought i would share this with you. me and a friend have been working on this off road trailer for a little while it a new idea using a independent suspension system. we are currently designing a camper set up to fit the trailer
Fatzook
 Posted: Wed May 22, 2013 10:44 pm |
What stops the axle from swinging sideways?
Independant suspension on a trailer is not new, but they always have 2 points of contact with the chassis. Same as any A-arm or wishbone found on any other type of independant suspension.
EDIT: It COULD work if you used a large enough member for the single swing arm..... like 200x50 with a 200mm 'hinge' at the chassis, but that will be quite weighty.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu May 23, 2013 8:03 am |
X2
Have a look at the suspension design used by track for their campers. Very elegant, and has some quite advanced wheel path design to prevent trailer sway. They moved away from a simple swing arm many years ago.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Thu May 23, 2013 9:00 am |
missmyljdaze
Joined: Tue Jul 05, 2011 7:16 am Posts: 2323 Location: perth
 Posted: Thu May 23, 2013 11:46 am |
Might be a good idea to chat to Ball, He has the privelige of repairing caravan and trailer suspension and stuff after they cark it due to NT tracks and roads.
Ball should have a few pointers on what works and survives in the real world.
stephen
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Mon May 27, 2013 6:43 pm |
Gwagensteve
 Posted: Mon May 27, 2013 7:18 pm |
I hate all those RHS swing arm designs- they just look so agricultural.
Google "track mc2 suspension"
The engineer at track trailer is a land rover guy and based the mc2 suspension on range rover parts- spring, shock and radius arm, and bushes. It could be very easily replicated with cheap wrecker parts from an old range rover and will outperform a swing arm design by a whole lot and be no harder to build.
SierraDan
 Posted: Mon May 27, 2013 7:22 pm |
The Tvan is my favourite trailer.
_________________ mlm
