It is currently Tue Nov 03, 2026 12:20 am
Vehicle: 1986 sj50 suzuki sierra
Post Posted: Wed May 22, 2013 9:59 pm
hey guys i just thought i would share this with you. me and a friend have been working on this off road trailer for a little while it a new idea using a independent suspension system. we are currently designing a camper set up to fit the trailer
Post Posted: Wed May 22, 2013 10:44 pm
What stops the axle from swinging sideways?
Independant suspension on a trailer is not new, but they always have 2 points of contact with the chassis. Same as any A-arm or wishbone found on any other type of independant suspension.
EDIT: It COULD work if you used a large enough member for the single swing arm..... like 200x50 with a 200mm 'hinge' at the chassis, but that will be quite weighty.
Post Posted: Thu May 23, 2013 8:03 am
X2
Have a look at the suspension design used by track for their campers. Very elegant, and has some quite advanced wheel path design to prevent trailer sway. They moved away from a simple swing arm many years ago.
Post Posted: Thu May 23, 2013 9:00 am
Coils, shocks, control arms, bushes, brackets, hubs, drums and brakes all in a kit ready to go for $1700
http://www.huntsmanproducts.com.au/inde ... ion-1.html
Post Posted: Thu May 23, 2013 11:46 am
Might be a good idea to chat to Ball,
He has the privelige of repairing caravan and trailer suspension and stuff after they cark it due to NT tracks and roads.
Ball should have a few pointers on what works and survives in the real world.
stephen
Post Posted: Mon May 27, 2013 6:43 pm
Post Posted: Mon May 27, 2013 7:18 pm
I hate all those RHS swing arm designs- they just look so agricultural.
Google "track mc2 suspension"
The engineer at track trailer is a land rover guy and based the mc2 suspension on range rover parts- spring, shock and radius arm, and bushes. It could be very easily replicated with cheap wrecker parts from an old range rover and will outperform a swing arm design by a whole lot and be no harder to build.
Post Posted: Mon May 27, 2013 7:22 pm
The Tvan is my favourite trailer.
Users browsing this forum: No registered users and 18 guests
