| Author |
Message |
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Sun Feb 05, 2012 12:57 pm |
ajsr wrote: how would you do that and have the axle run though a cocked bearing and seal??? cant see that working No idea, afaik it can't be done on the later model commodore borg warner diffs, only the 10 bolt salsbury's.
Ruthless
Joined: Tue Jan 11, 2011 8:50 am Posts: 1049 Location: Brisvagas
 Posted: Mon May 14, 2012 4:16 pm |
been testing the camber kit i made up it works and makes the car feel heaps better in corners just needed to modify it slightly and add some extra bits because it was crewing out axle seals being on that angle it worked better then a caster wedge
_________________ rust is lighter then carbon fiber
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Thu May 17, 2012 3:36 pm |
Gwagensteve wrote: Another consideration is what you are doing to the location of the inner axle. If I've figured it right, you are lowering the CV in the knuckle, which will force the inner axle down, taking out inner axle seals and loading the side gears in the diff. Who would have thought..... Steve.
steak_knife
Joined: Fri May 22, 2009 11:30 pm Posts: 21335 Location: Smart Ass Island
 Posted: Fri May 18, 2012 9:58 pm |
Gwagensteve wrote: Gwagensteve wrote: Another consideration is what you are doing to the location of the inner axle. If I've figured it right, you are lowering the CV in the knuckle, which will force the inner axle down, taking out inner axle seals and loading the side gears in the diff. Who would have thought.....Steve.  I did, but you can't tell the young......
_________________ I used to be indecisive,
Ruthless
 Posted: Fri May 25, 2012 6:34 pm |
fixed it tho with some modifications its all r and d going to make some more up for a few more cars
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Fri May 25, 2012 8:28 pm |
Ruthless wrote: fixed it tho with some modifications its all r and d going to make some more up for a few more cars When will you be taking orders?
_________________ Tell my arse, he actually gives a crap!
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Fri May 25, 2012 9:14 pm |
Haha monley..
_________________ mlm
Ruthless
 Posted: Sat May 26, 2012 6:56 am |
monley wrote: Ruthless wrote: fixed it tho with some modifications its all r and d going to make some more up for a few more cars When will you be taking orders?  after august when the next round is and i make sure the new one works and i should have another car running it
supa_slim
Joined: Mon Jan 31, 2011 9:15 am Posts: 444 Location: Redbank Plains
Vehicle: 85.Ruf. rear air locker
 Posted: Sun May 27, 2012 10:08 am |
pics of the camber on a car
Ruthless
 Posted: Sun May 27, 2012 6:11 pm |
here you go lance its a shit photo but you get the general idea and see the bar that we made that replace the one you got
alien
 Posted: Wed May 30, 2012 8:34 am |
looks like your shackle is twisting too?
Ruthless
 Posted: Wed May 30, 2012 8:53 am |
thats the fact everything is really badly bent from a few rolls
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Thu May 31, 2012 6:38 am |
yeah you wouldn't know it had a camber change, craigs car probably is all bent like that anyway from jumps
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Fri Jun 01, 2012 12:52 pm |
steve wrote: yeah you wouldn't know it had a camber change, craigs car probably is all bent like that anyway from jumps  My Coily has a heap of camber... bent housing probably from jumps also!
