It is currently Mon Nov 02, 2026 6:18 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Sun Feb 05, 2012 12:57 pm
ajsr wrote:
how would you do that and have the axle run though a cocked bearing and seal??? cant see that working
No idea, afaik it can't be done on the later model commodore borg warner diffs, only the 10 bolt salsbury's.
Post Posted: Mon May 14, 2012 4:16 pm
been testing the camber kit i made up it works and makes the car feel heaps better in corners just needed to modify it slightly and add some extra bits because it was crewing out axle seals being on that angle it worked better then a caster wedge
rust is lighter then carbon fiber
Post Posted: Thu May 17, 2012 3:36 pm
Another consideration is what you are doing to the location of the inner axle. If I've figured it right, you are lowering the CV in the knuckle, which will force the inner axle down, taking out inner axle seals and loading the side gears in the diff.
Who would have thought.....
Post Posted: Fri May 18, 2012 9:58 pm
Image I did, but you can't tell the young...... :roll:
Post Posted: Fri May 25, 2012 6:34 pm
fixed it tho with some modifications its all r and d going to make some more up for a few more cars
Post Posted: Fri May 25, 2012 8:28 pm
When will you be taking orders? :)
Post Posted: Fri May 25, 2012 9:14 pm
Haha monley..
Post Posted: Sat May 26, 2012 6:56 am
after august when the next round is and i make sure the new one works and i should have another car running it
Vehicle: 85.Ruf. rear air locker
Post Posted: Sun May 27, 2012 10:08 am
pics of the camber on a car
Post Posted: Sun May 27, 2012 6:11 pm
here you go lance its a shit photo but you get the general idea and see the bar that we made that replace the one you got
Post Posted: Wed May 30, 2012 8:34 am
looks like your shackle is twisting too?
Post Posted: Wed May 30, 2012 8:53 am
thats the fact everything is really badly bent from a few rolls
Vehicle: 75 Cruiser
Post Posted: Thu May 31, 2012 6:38 am
yeah you wouldn't know it had a camber change, craigs car probably is all bent like that anyway from jumps :rofl:
Vehicle: SJ80, SE416
Post Posted: Fri Jun 01, 2012 12:52 pm
My Coily has a heap of camber... bent housing probably from jumps also!
