It is currently Sun Nov 15, 2026 1:24 pm
Post new topic Reply to topic  [ 302 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
Post Posted: Sat Mar 12, 2011 10:49 pm
with 6.5 and 4.6s your looking at 4200 at 100 in high range from what i can figure
im looking at about 3700
if i go back to 3.7 diffs and get 4.1 transfer gears i will be about 3400
Post Posted: Sat Mar 12, 2011 10:56 pm
is that 4200 rpm on 33's?
Post Posted: Sun Mar 13, 2011 12:37 am
yeah i believe so unless i have it wrong
Post Posted: Sun Mar 13, 2011 11:08 pm
Im going 4.6 diff gears for strength over the 3.9's
I also have 4.9 transcase and have 33's but was thinking I might go 35's.
Mine
J20a/AW4/4.9/4.6/31 = 3400 @ 100klms
J20a/AW4/4.9/4.6/33 = 3300 @ 100klms
J20a/AW4/4.9/4.6/35 = 3200 @ 100klms
I did think that 4.1 gears would have been plenty but I got convinced by a mate to go 4.9's
I do have a 1L case here but Im thinking I might be good for Engineering,RWC, Rego etc.
Post Posted: Sun Mar 13, 2011 11:17 pm
yours being the AW4 has a much higher gear range though.
the manual is much lower.
aw4 is
1st 2.826
2nd 1.493
3rd 1.000
4th 0.730
5th N.A.
Rev 2.703
5 speed is 3.652
1.947
1.379
1.000
0.864
3.670
Post Posted: Sun Mar 13, 2011 11:50 pm
So my J20 vit runs at 3250rpm @100 on stocko tyres. It has 4.6 diff gears and 1:1 high range. Standard tyre is a 205/65 R16 (26.5").
My ute now has J20 and 5sp, 6.5:1 transfer (20% reduction over standard WT gears), 4.6 diff gears, and 33's (22% taller than stock SV420)
so what RPM will it now do at 100kph? I also have a set of 5.14's for transfer, but there is only a 1.7% decrease in reduction between the 5.14's and 6.5's.....
Post Posted: Mon Mar 14, 2011 12:06 am
with my cals you will be doing 4251.180 at 100 ks in 5th
with 5.1s you will do 4200.870
3.7s and standard transfer you would do 2850.872
3.7s with 4.1s = 3196.861
4.6s and 4.1 transfer your still gonna be doing 3974.476
Post Posted: Mon Mar 14, 2011 12:08 am
standard j20 vit should be doing 3132.498 in 5th at 100
Post Posted: Mon Mar 14, 2011 12:12 am
shit
Post Posted: Mon Mar 14, 2011 12:18 am
4.3 diffs?
How about 4.6's and WT transfer?
Post Posted: Mon Mar 14, 2011 12:19 am
tanshi wrote:
4.3 diffs?
Pretty rare aren't they?
How would they stack up with a 4.16 T/Fer?
Post Posted: Mon Mar 14, 2011 12:25 am
they arent the most common diffs in the world as far as i know.
doesnt really help alot any way. gives you 3700 at 100
4.3 and a standard case gives you 3300
Post Posted: Mon Mar 14, 2011 1:47 am
How is a 4.6 diff stronger than a 3.9 diff?
Post Posted: Mon Mar 14, 2011 1:51 am
i get the impression pete wants to goto a vitara rear diff and housing at some point?
Post Posted: Mon Mar 14, 2011 2:05 am
Yes I do. Which is why the 4.3 would be the lowest possible ratio I could use for the rear diff.
And I think damo was commenting on Remydog's post :wink:
Post Posted: Mon Mar 14, 2011 2:07 am
ahh yeah i should have red that shouldnt i
Post Posted: Mon Mar 14, 2011 2:10 am
It answers my question though, so thanks.
Post Posted: Mon Mar 14, 2011 2:34 am
Anyone know what model GV's had 4.3's? :?
Post Posted: Mon Mar 14, 2011 2:42 am
there are probably others but the new 3.2 4 door auto has 4.3s
Post Posted: Mon Mar 14, 2011 2:48 am
94-98 2 1.6L MPFI 3 speed auto
94-98 2D 1.6L MPFI 16V SOHC 3 speed auto
04-05 Grand Vitara/XL7 2.5L V6 5 speed manual
also from what i can find
Post Posted: Mon Mar 14, 2011 7:18 am
Have emailed you a gear ratio spread sheet Pete.
Have a look and see what combo you can come up with.
Post Posted: Mon Mar 14, 2011 7:21 am
Basicly going bigger tyres puts more load on the Pinon, etc
This explains it pretty well.
http://www.trailtough.com/index.php?opt ... &Itemid=60
Post Posted: Mon Mar 14, 2011 7:25 am
Pete
Your j20a/vit 5spd/4.6 diffs with a 4.1 trans.
I get 73 Final crawl ratio with 3600rpm @100klms with 33's
This is very similar to what 00zuk runs
Post Posted: Mon Mar 14, 2011 7:31 am
remydog05 wrote:
Pete
I could live with that.
And thats for the email :wink:
Post Posted: Sat Mar 26, 2011 10:25 am
as my motor turned up on a pallet i have never had the standard exhaust ( besides my hyper gonad custom manifold). turns out after a cleanup i have a fair bit of exhaust here off a few different cars, so
can someone tell me the diameter of the standard exhaust tube and also the diameter of them flash extractors some you cool kids have? 8)
i'm after a silent car but don't want to choke it to death like my old maruti running a g16 and standard 1lt pee shooter exaust :lol:
Post Posted: Sat Mar 26, 2011 7:02 pm
Could someone please tell me what my rpm will be @100kmh
With. 6.5 transfer and 4.11 diff gears with 33's
F#%ING [P] PLATER
 Profile YIM
Post Posted: Sun Mar 27, 2011 12:30 am
this isn't a gear calulator thread :|
but because i'm a nice person
http://www.rocky-road.com/calculator.html
oh all right it will be doing about 3700 rpm. now back to the topic
Post Posted: Sun Mar 27, 2011 12:33 am
Standard pipe size is 2" press bent. I'm running 2" mandrel on mine for a slight performance gain without all the theatre that larger pipes add :lol:
Post Posted: Sun Mar 27, 2011 12:36 am
thanks Pete. do you know roughly the diameter of the header tube? if i get tight and adventurous i might have a go at some :?
Users browsing this forum: No registered users and 64 guests
