It is currently Thu Nov 05, 2026 5:24 pm
Post new topic Reply to topic  [ 302 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
Post Posted: Sun Mar 27, 2011 12:51 am
mr.green wrote:
thanks Pete. do you know roughly the diameter of the header tube? if i get tight and adventurous i might have a go at some :?
I would have to take the pipes off my vit to find out, as I chucked the cast headers a while ago.
I can get the size of the extractors if you like...
Post Posted: Sun Mar 27, 2011 12:59 am
yeh sorry i meant extractors, or i guess i can measure the cast manifold ports and copy that....... Good idea :!: :oops: :crazy: :)
Post Posted: Sun Mar 27, 2011 1:04 am
I've been tempted to make my own extractors too, as I am having far too many clearance issues with the hurricane J20 pipes.
Post Posted: Sun Mar 27, 2011 2:08 am
mr.green wrote:
94BAZOOKA wrote:
Could someone please tell me what my rpm will be @100kmh
With. 6.5 transfer and 4.11 diff gears with 33's
this isn't a gear calulator thread :|
but because i'm a nice person
http://www.rocky-road.com/calculator.html
oh all right it will be doing about 3700 rpm. now back to the topic
Thanks mate
F#%ING [P] PLATER
 Profile YIM
Post Posted: Sun Mar 27, 2011 7:21 am
got my exhaust done, throtle response is no soo much smoother!
cost a bit more than i wanted to spend but it is now exactly what i want!
Post Posted: Sun Mar 27, 2011 7:50 am
did you use the hurricane extractors or go full custom?
Post Posted: Sun Mar 27, 2011 12:02 pm
in the end i customised the hurricane extractors. heated and bent them a bit. Pete its running the whole engine alot lower than me so his issues are going to be different
Post Posted: Mon Apr 04, 2011 12:39 pm
im thinking about a j20 for a jimny, does any body know power specs on them
dodgy brothers mechanical
Post Posted: Mon Apr 04, 2011 12:56 pm
yep
Post Posted: Mon Apr 04, 2011 1:07 pm
can u tell me them plz
Post Posted: Mon Apr 04, 2011 1:09 pm
Is your google broken? :roll:
Power 94kW @ 6000rpm Torque 174Nm @ 2900
from here
Post Posted: Mon Apr 25, 2011 8:44 am
just out of curiosity, Tanshi & Fatzook?
What do you consider the center of the engine in reguards to mounting the engine in the sierra?
The reason I ask this is because I was looking at mine today thinking I really have to get back to this asap, and I was looking at where mine is in relation to the chassis rails and if there was an angle on the eng/auto in relation to the rails, etc or if they are directly parallel. Although I used the TT mounts it looks a bit wrong when looking from the front.
I might take a measurement from rail to crank bolt?
rails to sump plug
and something at the rear of the engine.
I would have said my auto xmember would be almost 100% on the dot. When looking from above or below the rear auto shaft is almost a perfect line up to the transfer case flange. the transcase just needs to come up approx 35 maybe as high as 50mm max to line up real well.
I realize it will be hard to tell as we have all mounted them a little different but there might be something similar?
Post Posted: Mon Apr 25, 2011 10:08 am
I used the crank bolt as a centre line. As far as rotation is concerned, your auto sump should be level. If you want I can take a pic of how the J20 sits in my vit?
having said this, you will find that your motor really only sits in one spot, thanks to the packaging constraints that aren't present in the vitara. Be sure you leave room for fuel and brake lines, and steering shaft on drivers side, and the exhaust manifold/ A/C compressor on the passengers side.
Post Posted: Tue Apr 26, 2011 11:27 pm
tanshi wrote:
Pete its running the whole engine a lot lower than me so his issues are going to be different
To me it was a bit suprising how much difference this makes.
The G16 in my Sierra is dropped 50mm from standard and makes fitting the exhaust past the passenger side engine mount a lot more difficult. Obviously this doesn't translate directly as the J20 will be different, but I won't be suprised if he ends up with a custom manifold.
Post Posted: Wed Apr 27, 2011 12:12 am
Yep.
I have a complete pipe kit here from hurricane. So I will be making a shortened version of their headers.
Post Posted: Wed Apr 27, 2011 10:58 pm
Thanks Pete will do some measuring and see how it sits.
I looked when the eng/auto was in the GV and it seemed to be ever so slightly angled back? EG front high transcase low by a few degrees only.
Again I will have a good look and measure when I get a chance.
Post Posted: Sun May 15, 2011 11:15 am
I have pumped the tunnel. I have gone way further than I needed to as I may go to an auto in the future, and the oil pan makes them alot wider than the 5sp. I have templates for these panels if you reckon you would like to do as I have done :wink:
Pete have you still got these templates?
What size is your thermo? EG what CFM.
Im thinking something about 1200 should be fine?
What dash and loom do you run? Im wondering what might be best for wring etc? And VSS, etc
As I have loads of options! My LWB is a NT 85 but I dont have a NT tacho cluster or I have a WT dash, loom and cluster thanks to mr green, OR I have a Maruti loom I found today also!!
Post Posted: Sun May 15, 2011 11:18 am
OH and both mine and Tanshi's sits about 20-25mm to the passenger side!
it must be the TT mounts.
Post Posted: Sun May 15, 2011 12:52 pm
Yeah mine is mayve 10mm offset to D/S.
Post Posted: Sun May 15, 2011 10:39 pm
Im considering parting my sierra so you can always buy mine, 99% done ;)
Post Posted: Sun May 15, 2011 10:56 pm
What the??
You just did it!!!!!!!????
Post Posted: Sun May 15, 2011 11:45 pm
yeah, its not finished and it wouldnt be a big dea to finish it, but the rest of the car needs so much work, Considering a tow vehile/daily and a trailer.
Post Posted: Sun May 15, 2011 11:57 pm
Really? What needs doing on 'the rest'?
Post Posted: Mon May 16, 2011 12:03 am
rust repairs in floor (minor) and fitt my sparcos
do a proper full RUF ( at the moment im on ext shackles and carry springs)
virtual lift and refit my double black flares
cut sills and box section fill
replace drivers front guard (fills snokel hole)
Pull the Airlockers out replace with 3.7s
put 4.1s in transfer
body work and paint
new front bar.
and thats just what i can think of right now
Post Posted: Mon May 16, 2011 12:06 am
body work and paint
new front bar.
hmmmm.
But how does it drive? :lol:
Post Posted: Mon May 16, 2011 12:12 am
once i can get rid of the drive line vibrations which threaten to shake the chassis to peices and obliterate the transfer case, im sure it will be really nice.
the RUF is the bifg thing, handles like shit and death wobbles to the max!!
Post Posted: Mon May 16, 2011 11:04 am
Give ya $20 for it..... :P
Post Posted: Mon May 16, 2011 11:11 am
for the glove box lid, SOLD!
Post Posted: Tue May 17, 2011 3:16 am
Still got the templates pete? what size fan?
Post Posted: Tue May 17, 2011 6:07 am
Sorry mate I missed this post :oops:
Yes I have the teplates. I could cut you some flares if you like. (1.2mm or 1.6mm Mild or Zinc)
You may have to scollop and trim them slightly to suit your floor, but the hard work would be done :wink:
I have a single 14" SPAL skew blade thermo 1720CFM. Available from PWR.
I'm running a plastic 87 NT 1L dash with no tacho (same as Maruti). VSS is still to be built into the 1L speedo by Danny boy. :lol:
Pete
Users browsing this forum: No registered users and 30 guests
