| Author |
Message |
bumstein
 Posted: Sun May 17, 2020 5:25 pm |
Incidentally I was thinking about running the coolant through a small radiator (similar in size to the heater core) in the engine bay when the heaters off and coolant diverted away from the heater core. Haven’t got too much planned yet but it was a though
I’ve also taken rough temperature readings at several spots on the G16B in a Baleno running at full temp. At some point I’m hoping to get similar readings from one in a Sierra with the usual setup and again with the three way tap setup. Just to see if there’s anything it can tell us
rexhunta
Joined: Sun Jan 26, 2014 9:03 am Posts: 212 Location: Leschenault, WA.
Vehicle: 2020 Vitara Turbo
 Posted: Sun May 17, 2020 7:13 pm |
bumstein wrote: Just to see if there’s anything it can tell us it'll tell you to stop overthinking !
bumstein
 Posted: Sun May 17, 2020 8:01 pm |
rexhunta wrote: bumstein wrote: Just to see if there’s anything it can tell us it'll tell you to stop overthinking ! Indeed you’re right! But easy to do when I get the motor in and on the off chance it’s interesting (unlikely)
rexhunta
 Posted: Sun May 17, 2020 8:22 pm |
bumstein wrote: rexhunta wrote: bumstein wrote: Just to see if there’s anything it can tell us it'll tell you to stop overthinking ! Indeed you’re right! But easy to do when I get the motor in and on the off chance it’s interesting (unlikely) know i'll get e-bashed, just throw a vitara rad at it. Worst case mount the rad upside down on the roof with 4 spoilers directing straight into it !
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sun May 17, 2020 8:34 pm |
I’ve never been convinced about the fit of the vitara radiator, especially with power steering.
bumstein
 Posted: Sun May 17, 2020 9:29 pm |
rexhunta wrote: know i'll get e-bashed, just throw a vitara rad at it. Worst case mount the rad upside down on the roof with 4 spoilers directing straight into it ! A novel idea!!
rexhunta
 Posted: Sun May 17, 2020 10:02 pm |
Gwagensteve wrote: I’ve never been convinced about the fit of the vitara radiator, especially with power steering. I had both P/s and the Vitara Rad in my SJ50. Bumstein knows our weather down here in the summer. Our beaches our extremely soft and work motors hard, I had little to no problems with heat at all thanks to it, couldn't say the same with the Sierra rad. Of course, this is all Personal opinion, and driving to the conditions of the state/area I live in.
Gwagensteve
 Posted: Mon May 18, 2020 6:53 am |
rexhunta
 Posted: Tue May 19, 2020 6:48 am |
Gwagensteve wrote: What fan and shroud? Everything was from the Vitara. Made my own custom bottom rad mount and pushed rad to the right and lower.  not the best pic but this shows the p/s box, the rad and the shroud.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Aug 17, 2022 6:21 pm |
Is this the easy (but expensive) button for a sump? From a GV G16b, has the mount holes for the crank angle sensor and a rear hump. I am swapping into a maruti and don’t have a donor 1.3L sump so if this is a bolt on solution it’s probably worthwhile. https://www.ebay.com/itm/393147443927
Gwagensteve
 Posted: Thu Aug 18, 2022 7:17 am |
