It is currently Fri Nov 13, 2026 10:22 am
Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
Post Posted: Sun May 17, 2020 5:25 pm
Incidentally I was thinking about running the coolant through a small radiator (similar in size to the heater core) in the engine bay when the heaters off and coolant diverted away from the heater core. Haven’t got too much planned yet but it was a though
I’ve also taken rough temperature readings at several spots on the G16B in a Baleno running at full temp. At some point I’m hoping to get similar readings from one in a Sierra with the usual setup and again with the three way tap setup. Just to see if there’s anything it can tell us
Vehicle: 2020 Vitara Turbo
Post Posted: Sun May 17, 2020 7:13 pm
it'll tell you to stop overthinking !
Post Posted: Sun May 17, 2020 8:01 pm
Indeed you’re right! But easy to do when I get the motor in and on the off chance it’s interesting (unlikely)
Post Posted: Sun May 17, 2020 8:22 pm
know i'll get e-bashed, just throw a vitara rad at it. Worst case mount the rad upside down on the roof with 4 spoilers directing straight into it !
Post Posted: Sun May 17, 2020 8:34 pm
I’ve never been convinced about the fit of the vitara radiator, especially with power steering.
Post Posted: Sun May 17, 2020 9:29 pm
A novel idea!! :D
Post Posted: Sun May 17, 2020 10:02 pm
I had both P/s and the Vitara Rad in my SJ50. Bumstein knows our weather down here in the summer. Our beaches our extremely soft and work motors hard, I had little to no problems with heat at all thanks to it, couldn't say the same with the Sierra rad.
Of course, this is all Personal opinion, and driving to the conditions of the state/area I live in.
Post Posted: Mon May 18, 2020 6:53 am
What fan and shroud?
Post Posted: Tue May 19, 2020 6:48 am
Everything was from the Vitara. Made my own custom bottom rad mount and pushed rad to the right and lower.
not the best pic but this shows the p/s box, the rad and the shroud.
Post Posted: Wed Aug 17, 2022 6:21 pm
Is this the easy (but expensive) button for a sump? From a GV G16b, has the mount holes for the crank angle sensor and a rear hump. I am swapping into a maruti and don’t have a donor 1.3L sump so if this is a bolt on solution it’s probably worthwhile.
https://www.ebay.com/itm/393147443927
Post Posted: Thu Aug 18, 2022 7:17 am
Yes.
Users browsing this forum: No registered users and 52 guests
