It is currently Sun Nov 15, 2026 2:07 pm
Post new topic Reply to topic  [ 302 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 11  Next
Post Posted: Sat Jan 01, 2011 4:43 am
tanshi wrote:
i have a thermo that was already on the g16, it fixes to the front of the radiator so it will be retained.
biggest head ache i can see is the exhaust manifold. Given the difficulty getting extractors for these things.
I dont know what these are like but give them a call I guess?
Not cheap tho!
http://www.suzisport.com/shop/
Post Posted: Sat Jan 01, 2011 4:44 am
ah bugger the link doesnt work
go to 2L vit under performance and they have extractors.
Post Posted: Sun Jan 02, 2011 10:56 am
i have had a price in for full custom extractors for $500
hurricane also make them but they are similarly priced.
so 500 is will have to be.
Post Posted: Sun Jan 02, 2011 12:35 pm
I bought a set of J20 extractors for mine just a few weeks ago :? Wasn't at all hard to find :?
EDIT: Hurricanes for $290 +GST.
Post Posted: Sun Jan 02, 2011 1:49 pm
But you eng mount's in the factory spot...
Post Posted: Sun Jan 02, 2011 1:55 pm
Yeah but engine mounts are easily moved. Specially when doing an engine conversion :wink:
Post Posted: Sun Jan 02, 2011 9:33 pm
:roll:
Post Posted: Sun Jan 02, 2011 9:40 pm
5 hundy for extractors?
Seems like a good excuse to turbo it 8)
Post Posted: Sun Jan 02, 2011 9:42 pm
8O
Post Posted: Sun Jan 02, 2011 10:29 pm
Do you think they would go close to fitting up Ok in a sierra?
Or even some minor adjustments?
Post Posted: Mon Jan 03, 2011 12:12 am
Dunno. But if Tanshi wants to test fit them he had better be quick :wink: Once they go on the Vit they aint comin off again 8)
Post Posted: Mon Jan 03, 2011 1:06 am
i can't imagine they would go within a bulls roar of fitting. the standard manifold points directly at the top of the chassis rail and in mine the flange was roughly 2'' from the rail. will be custom for me.
Post Posted: Mon Jan 03, 2011 5:59 am
some detailed pics pete?
i would love to borrow them if thats at all posible just to hang in place and see.
Post Posted: Mon Jan 03, 2011 6:14 am
Pics.
Let me know if you need another angle.
Post Posted: Mon Jan 03, 2011 8:04 am
:oops: humble pie for me again. looks like it hugs the motor a lot better than the original manifold.
Post Posted: Mon Jan 03, 2011 8:12 am
did you pick these up for a speciial price for you Pete, or would you mind sharing the where you picked them up? You can PM if ya want
Post Posted: Mon Jan 03, 2011 8:14 am
The J18 does to (std) but land's on his eng mount.
Looking at them, they may fit, the join of 1 & 4 may need a massage..
Post Posted: Mon Jan 03, 2011 8:16 am
yeah highway stars jimny oones needed similar. to save that kind of money i would make the sacrifice
Post Posted: Mon Jan 03, 2011 8:17 am
We had to do this when fitting the G13bb Extractors to my G16b. From memory we heated them up, and bent them a bit using an acro prop off the railway line in the shed roof 8O :lol:
edit...You beat me! :lol:
Clearance Hole Technology :P
Post Posted: Mon Jan 03, 2011 8:34 am
8O
Post Posted: Mon Jan 03, 2011 9:05 am
If you can get those ones of petes to fit then I will be chasing a set for sure!
Oh and buy the way, what are you going to do about the rest of your exhaust Tanshi? Custom Im guessing?
Post Posted: Mon Jan 03, 2011 9:42 am
i have the entire standard vit exhaust so for the time being i will make that fit.
when i have a spare doller or two i may go custom
Post Posted: Mon Jan 03, 2011 10:12 am
PM'd.
Yes. Special price :wink: I think retail is around $390 inc.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Jan 03, 2011 8:58 pm
MPH on eBay will make custom ones so you dont have to move your mounts. I was quoted $250 including delivery for GTI flange with sierra extractors and sensor mount.
here are the details:
$250 delivered you can order on 0413745661 cheers Rod
Post Posted: Mon Jan 03, 2011 9:08 pm
I called ROD about J20a pipes as I had bought G16B ones from him in the past. He wasn't interested.
I think the only reason he said yes to you is because he has the parts and jigs for sierra pipes, and GTI pipes. So making a combo is easy.
Custom systems almost always require the recipient vehicle to be present during manufacture.
Post Posted: Mon Jan 03, 2011 11:32 pm
yep. not surprising.
oh well.
Post Posted: Tue Jan 04, 2011 4:43 am
after a test fit (thanks Fatzook). the hurricane ones are about 15mm from fitting straight on. About 100 mm down from the boss for the oxy sensor. however. being that the two pipes are offset I think we can have a set heated and bent slightly and they will clear every thing. Exhaust problem solved!!! And PM sent Pete.
Post Posted: Tue Jan 04, 2011 7:44 am
Good Shit! :D :D
Post Posted: Sat Jan 08, 2011 10:13 pm
mmm I might see if you can get me a set too pete!
Hey Tanshi how much clearance do you think you will have from the firewall to the back of the engine? And can you see any probs with it RE getting to the back in case you need to do anything? (Keeping in mind I realize there is pretty much bugger all on the back of a J20a.)
Post Posted: Tue Jan 11, 2011 12:00 am
where i have mounted mine i have 15mm to the closest spot on the back. i.e crank angle sensor.
there is heaps of room other than that.
Users browsing this forum: Google [Bot] and 70 guests
