It is currently Tue Oct 20, 2026 12:56 pm
Post Posted: Mon Sep 17, 2012 10:25 am
hey guys i have a sierra electric dizzy to go in my f10a
it has a resistor on the coil, do i need to remove it and install or is there any other tricks?
Phil
Vehicle: Yellow Ute
Post Posted: Mon Sep 17, 2012 11:33 am
I just used the 1.3 coil and dizzy and took the ballast resistor out.
Post Posted: Mon Sep 17, 2012 3:45 pm
cheers is the wiring the same color?
Vehicle: Yellow Ute
Post Posted: Mon Sep 17, 2012 5:11 pm
Not sure, mine is a Maruti Dizzy which has a black wire with white stripe that goes to positive side of the coil and a brown wire which goes to the negative. Then a black wire at the base of the dizzy housing which I just ran to the body.
The wiring diagram on Suzuki Info says it is black wire with white trace that goes to positive side of the coil, brown with white trace to negative of the coil.
Post Posted: Mon Sep 17, 2012 6:29 pm
thanks very much mate
Users browsing this forum: Google Adsense [Bot] and 70 guests
